I tried to change the upper steering column bearing and had to remove that entire upper tilt part of the column. In the process I had the remove the ignition from the column. I also had to remove the internals part of the ignition area to get the actuator to release so I could remove the column. I am having hell getting it all back together and I cannot find a thread for it. Does anyone have instructions on how to put this POS back together. I am losing it.
