1978 - 1996 Big Bronco
mass air conversion kit, idle problems
Old Jul 7, 2007 | 04:35 PM
dkilventon's Avatar
dkilventon
I have a 1990 bronco w/ a 351w. I just put on a mass air conversion kit and the truck starts and runs rough. It smooths out at higher RPM. could it be that I have a lower intake gasket leak or a idle air bypass problem? ohh ya it will smooth out for a minute after it warms up and runs at like 800rpm's but then after a minute the idle drops and it idles like crap again.. ahhhhh please help..
Old Jul 9, 2007 | 08:36 AM
Kemicalburns's Avatar
Kemicalburns
pull codes, what computer are you using. what kinda mass air kit did you get. is the o2 sensor hooked up? injector firing order setup for the 5.8?
Old Jul 9, 2007 | 10:17 AM
dkilventon's Avatar
dkilventon
I have not had a chance to pull the codes yet, but the kit is from total performance, it has a overlay harness and reprogramed eec-IV mustang computer. All the sensors are hooked up to the original wiring harness and the overlay harness is connected to that and the computer.
Old Jul 9, 2007 | 10:40 AM
Kemicalburns
did you remove the vacum line going to your map sensor? pulling codes should be your next step
Old Jul 9, 2007 | 07:41 PM
dkilventon's Avatar
dkilventon
ya I removed the MAP sensor vacume line, I'll pull the codes a see what comes up...
GRNMSTR
Escape & Escape Hybrid
Nov 3, 2011 05:27 AM
RKG
Jul 6, 2006 06:15 PM
s.bittner
18
May 26, 2006 02:24 PM
bluoval
Feb 9, 2002 10:20 PM
