IDM Problem
Old Jul 7, 2007 | 11:58 AM
SrqScion's Avatar
SrqScion
IDM Problem
Ok, i've been reading up but can't find the answer I'm looking for. Can an IDM cause just one injector not to fire or no? I still have had a rough idle and low power even after UVC harnesses, vc gaskets, IPR o rings, ICP, CPS, and cleaning everything. Ran a buzz test and #1 isn't working. Ohms out fine and these injectors only have about 2k miles on them, so I guess IDM is the only other thing right? Is there a voltage check I can do at the connector or should I just try to find an IDM to try? Thanks guys
Old Jul 7, 2007 | 12:20 PM
Action4478's Avatar
Action4478
Can you move # 1 to a different hole & see if the problem follows?....
Also ,is #1 squirting oil the same as all the rest?...
Does the IDM have water in it?....
Old Jul 7, 2007 | 12:23 PM
SrqScion's Avatar
SrqScion
I'd rather not have to pull an injector. I have a friend with a wrecked 97, I will prob just go pull his IDM tonight and try it. I just wasn't sure if idm can cause one cylinder to drop or not. Didn't run the engine with the vc's off so I don't know. I did make the mistake of pressure washing the ingine when i first bought the truck so that is possible, and the truck sat in a field for over a year too before I got it. Thanks
Old Jul 7, 2007 | 07:44 PM
powerstroked162's Avatar
powerstroked162
if it did it would be a freak thing. Usually, once the IDM's go they go completely with no mercy. I would go back through your VC harnesses and see if they are toasted. Are they new from the dealer or outta your buddies wrecked '97?
Cowboy Steve
Old Jul 7, 2007 | 08:00 PM
tjbeggs's Avatar
tjbeggs
While the IDM's normally either drop dead or drop 4 cylinders at a time but it is possible that it could drop one. you said the injector ohmed out good right. at the valve cover connector it was less than 3 ohm? Easiest thing is to try another IDM. if thats not it you need to test the wiring right at the IDM connector.
Old Jul 8, 2007 | 12:51 AM
SrqScion's Avatar
SrqScion
Yeah all my injectors across the board read at 3.6 at the vc plug. I just did UVC harnesses and vc gaskets today. They are all new from international. I got the IDM from the 97 tonight but going to check all the engine harness wires before pluggin it in. Can an injector be bad and still ohm out good?
Old Jul 8, 2007 | 12:53 AM
powerstroked162
I dont think I have evr heard of that but that dosnt mean it cant happen. Hope you find out whats keepin your truck down. Try the IDM swap and see where that leads you. Good luck!
Cowboy Steve
Old Jul 8, 2007 | 12:57 AM
SrqScion's Avatar
SrqScion
thanks, im going to get back on it early am... does anyone have a pin layout of the idm harness? As in what pins run which injectors?
Old Jul 8, 2007 | 08:37 AM
Cuda_jim's Avatar
Cuda_jim
Does the engine rev up in neutral to the governed speed +/- 3300 rpm? If so, the IDM is good. The IDM doesn't care if the engine is loaded or free wheeling.
PM me your email address, I will send you the pin outs for the IDM.
BTW: There is 120V AC coming out of the IDM.
Old Jul 8, 2007 | 11:17 AM
SrqScion's Avatar
SrqScion
Ok... Ohm'd out the engine harness to all injector, all are good. Nothing shorted to ground, checked all injectors again, all ohm'd good. Put the new IDM in, presto... No more 7 cylinder powerstroke. Still get's a little rough on the idle once warm, but I also need a new flywheel. Thanks for the help guys! Also, is there anyone who rebuilds IDM's? Wouldn't mind sending mine out to get rebuilt for a spare.
Old Jul 8, 2007 | 02:15 PM
Cuda_jim's Avatar
Cuda_jim
Take a look here for some insight into the IDM. This link is for a mod but it will give you something to think about. Like a 120V IDM vs 110V, it's worth an extra 5-10 HP & 30 ft lbs of torque
http://www.forgotton.net/diesel/idmmod/index.htm
Old Jul 8, 2007 | 02:57 PM
powerstroked162
Beans Diesel Performance will rebuild your IDM to either stock 94-97 specs, or 99.5-03 specs, or they can mod it to do a full 140v. Give them a shot they arent to spendy.
Cowboy Steve
Old Jul 8, 2007 | 03:42 PM
tjbeggs's Avatar
tjbeggs
Check out this search on Ebay. Any of the IDM's from the "auto computer exchange" are excellent.
http://motors.search.ebay.com/IDM_Pa...40QQsacatZ6028
Old Jul 8, 2007 | 03:57 PM
SrqScion's Avatar
SrqScion
Thanks Tim, I saw those but wasn't sure if they were any good. I'll prob go ahead and pick one up
Old Jul 28, 2007 | 09:40 AM
elvia's Avatar
elvia
Man there sure are many things for me to learn. So many symbols and aberrations But I am pretty good at searching.
Whats a IDM?
Here you go.
The Injector Driver Module IDM controls power to the fuel injectors based on information received from the PCM. The IDM receives two digital control signals from the PCM: the Fuel Delivery Control Signal and the Camshaft Position Signal. The Fuel Delivery Control Signal is used by the IDM to control injection timing and injection duration. The CMP signal provides synchronization to the engine's first and the fifth injector (firing order, cylinders number one and four). The IDM verifies that fuel that Fuel Delivery Control Signal and CMP occur at valid timing intervals for synchronization.
as quoted from dieselsite
