Tool Kit
Old Jul 6, 2007 | 07:43 PM
peecubed's Avatar
peecubed
Tool Kit
I know that there was a jack and lug wrench originally available with these trucks, but was there any other tools that they could have come with originally. I have a tire iron that was stuffed in the back of my cab when I bought it. It was pretty useless until I bought the original hub caps and put them on ...they're impossible to get off without screwing up your wheel paint. The tire iron, aside from being used in breaking and setting the bead when replacing tires, has a perfect head to pop the hub caps off when being pryed against the tire.
Is this an original tool? Has anyone ever seen one of these before? I've put a few pictures of it below.
Old Jul 7, 2007 | 06:24 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Genuine Ford lug wrench...but 1953/56 hubcaps had red painted letters. The blue painted lettered hubcaps were used on late 1947, 1948 passenger cars, and 1948/52 F1 pickups.
Ford's from Model T days had a "full" complement of tools in a canvas bag. There was a two way spark plug socket, end wrenches, pliers, several screwdrivers, and an adjustable wrench. Since spare tires were originally optional, the jack and handle was not included. The tools were made by K. R. Wilson, and all had the Ford script on them. By the 1940's, the "full" complement of tools was reduced to a combo pliers/blade screwdriver (!), a two way spark plug socket and an adjustable wrench. When Ford went to the "innie" type of hubcaps, the jack handle came with a thin tapered curved end, to get the caps off the wheels. Every car swap meet you attend, someone is buying/selling these Ford tools.
btw. Baling wire was never in the tool kits, though many ppl joked at the time it should have been!
Old Jul 7, 2007 | 07:26 AM
ksmith203's Avatar
ksmith203
Great info numberdummy
Old Jul 7, 2007 | 08:33 AM
ALBUQ F-1's Avatar
ALBUQ F-1
There was also a crank for the engine, at least up thru '52, wasn't there? I have part of it (the offset crank) but not the actual piece that went thru the grille to the crank. Actually I have that piece but it has been cooty-bobbed; I suspect the original was worn out!
Old Jul 7, 2007 | 01:44 PM
peecubed's Avatar
peecubed
NumberDummy, I don't think it is a lug wrench as neither side of it has any way to take off lug nuts. It looks very similar to the tire iron shown in the pictures in the owners manual, thats why I thought it could be original. It doesn't have a ford script anywhere on it though. Oh, and this is on a 55 F100.
Old Jul 7, 2007 | 03:58 PM
NumberDummy
1953/56 refers to: 1953; 1954; 1955; 1956.
The original 1948/56 lug wrenches have the tapered curved end I mentioned in the above post = O1A-17035 (fits 1940-1956). The tire iron, lug wrench and jack were not a part of the original tool kit. Except for early Model T jacks, none of these tools have a Ford script on them.
Old Jul 7, 2007 | 08:51 PM
peecubed's Avatar
peecubed
I guess I don't know what this is supposed to mean then.
It obviously isn't a lug wrench because it doesn't take off lug nuts.
It obviously isn't the original tool to pop the hub caps off with since, as numberdummy stated, that was the reverse end of the jack handle.
BUT, it does still look like a tire iron and it does still pop off the hubcaps nicely. And if the spare was still optional in 55 ( I don't know if it was) how were you supposed to get your hub caps off if you didn't buy the jack and handle (since you wouldn't have a spare to put on)
Has anyone definetively seen a tire iron that came with a 55 Ford truck or was the tire iron even an option by then? And it is it the same as picture above?
Old Jul 7, 2007 | 10:38 PM
merten's Avatar
merten
peecubed
I just took a look at your gallery, awesome truck. Love the color. It looks like you painted the block letters on the hubcaps green to match the truck, nice touch.
Old Jul 8, 2007 | 03:22 AM
NumberDummy
On some trucks back then, the spare wheel came with the truck, the tire was optional! When the spare option was ordered, Ford included the jack, lug wrench AND a handle (rod) that the end of resembled a crank handle to raise and lower the jack. The jack fit under the truck and had a slot that the handle/rod went into. Because of the length, some folded in two. I don't know if the tire iron came with the tool kit. I can't remember ever seeing one at a swap meet, so I don't know if originals came with the Ford script.
Update: >>>Found in an old Ford Parts Catalog dated: May 1953.
78-17081 .. Wrench--Use as a Tire Iron ~ F100
davewild
349
Aug 30, 2020 10:17 AM
mtuck
29
Feb 27, 2017 08:19 AM
mbarrad
24
Apr 27, 2016 01:40 PM
fiftyfordfloored
39
Mar 13, 2015 04:11 PM
wmjoe1953
Oregon Chapter
May 3, 2011 10:45 PM
