fuel pump needed badly...
Old Jul 6, 2007 | 03:18 PM
camperspecial65's Avatar
camperspecial65
I am in need of an OE fuel pump...65 352 sealed carter type pump w/filter mounted below it...if anyone know where I can get one, let me know...casting numbers are as follows...4007, no letter after it and 6E29A which I would gather is its build date maybe...plz help...I had gotten a new one, non Carter but 1 1/2 lbs of pickup pressure sure as heck isnt cutting it...If anyone knows of or happens to have one around Id be most appreciative...also if anyone knows if this crosses over onto any cars for those with all the books that would be great too...
Thanks Loads Guys...cs65
Old Jul 6, 2007 | 04:33 PM
daveengelson's Avatar
daveengelson
Checked out Hollander Interchange Manual and appears there are few trucks and vehicles where the fuel pumps are interchangeable for the 65 w/ 352 but of the same vintage as your truck.There is also another listing but apparently it has a filter incorporated in the pump. Not likely going to find them in salvage yards and probably just as hard to find parts for than your 65 truck. The manual makes referrence to 70-72 models, does not indicate which models, but apparently those that do have the ident # stamped on the pump. The Ident. # listed in Hollander is RD410MF which does mean a heck of a lot to me. Anyhow, if able to make any sense out it good luck.
Comet 66, w/ 390, GT
Fairlane 66, w/390, GT
Ford Pass. LTD 65, w/ 352
65 thru 67, tr w/ 352
68-69 tr, w/ 360
Mercury 63-65, w390
dave
Old Jul 6, 2007 | 05:31 PM
jowilker's Avatar
jowilker
You should be able to get one from most any parts house. Anything that will work on a 360 for 76 will work on yours too.
John
Old Jul 6, 2007 | 09:33 PM
ddavidv's Avatar
ddavidv
LMC has them in their catalog, p/n 43-4715 $34.95
NPD has them also, p/n 9350-5A $30.95
Did you check this site? They may also carry them.
Old Jul 6, 2007 | 11:29 PM
adharvey2's Avatar
adharvey2
I got a Carter brand #4007 - pretty sure that was it - at Carquest a few months ago. May still have the box around if you need the number. It's the same pump the 292s used.
Old Jul 7, 2007 | 12:25 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally there were at least 5 different car & truck fuel pumps that would work. Ford replaced them ALL in 1972 with an updated part number.
D2TZ-9350-A .. Fuel Pump
Replaces: C3AZ-9350-R; C3AZ-9350-U; C4TZ-9350-A; C4TZ-9350-C; C9TZ-9350-A.
FTE member adharvey2 is correct. The same FE pump was used on 292's.
Old Jul 7, 2007 | 11:42 PM
Fords&Farmalls's Avatar
Fords&Farmalls
I just took my old fuel pump into the parts store and they had a bunch in stock. Was like 35-40 bucks or something like that. Shouldnt be a problem to find.
Good luck
Garrett
coupman35
41
Feb 10, 2017 10:01 AM
drivetrain
Nov 10, 2013 11:03 AM
fordf350camper
Feb 9, 2013 11:16 AM
zgator
Nov 3, 2006 06:47 PM
jnj4fords
Aug 16, 2006 07:46 AM
