ac short cycling
Old Jul 6, 2007 | 07:52 AM
jp4andmore's Avatar
jp4andmore
Smile ac short cycling
Hello to all, a few quick questions, i am going to buy a new ac clutch. I had to run and inline fuse
a href=https://www.ford-trucks.com/forums/s...earchid=462065
Old Jul 6, 2007 | 08:18 AM
92F150Flare's Avatar
92F150Flare
Welcome to FTE
What are your questions? Short cycling might be the clutch....but usually is low on fluid. Have you had it pulled down, vacuumed and re-charged? It needs that to dry it out if it leaked and was repaired. Generally.....if you don't...it just keeps not working right.
I'm shooting in the dark here.....so let us know more specifics. Truck, motor, and info on what led to the short cycling........you'll get help here.
Good Luck
Bob
Old Jul 6, 2007 | 08:46 AM
jp4andmore's Avatar
jp4andmore
why certainly truck buffs
1987 ford f150 six cylinder long bed single cab.
the ac short cyles for 30second or so. the fuse melted the fuse block, i put and inline fust to end this awful previous owner install. I have pushed the ac clutch and it dows hav pressure and it does have some resistance, the new inline fuel does not hot, Help, input, brainstorm, rigging, dumb idead, please help, thanks
Old Jul 6, 2007 | 08:55 AM
92F150Flare
If it's running...but not cooling and the PO did all that jerry-rigging.......I'd bite the bullet and take it to a reputable shop and let them test it.........More than likely the PO did other stuff too.......It sounds low on gas to me but I'm not an expert at all. Hang in here.....others will have suggestions.
Good Luck
Bob
Old Jul 6, 2007 | 09:21 AM
jp4andmore's Avatar
jp4andmore
there are no leaks at all. The PO installed a car alarm and radio despit wiring harnesses, the PO is or was an idiot I pumped it full of ra and i think it has not ran in some time, it problably busted the clutch
Old Jul 6, 2007 | 10:06 AM
albung's Avatar
albung
im willing to bet also that u are low on refrigerant
Old Jul 6, 2007 | 10:57 AM
jp4andmore's Avatar
jp4andmore
meter said blue
the meter set blue which acceptable, it would fire up the compressor for 30 seconds. Correct me if I'm wrong but not enough amps will not fire up th a/c
albran
Oct 10, 2006 06:46 PM
