If you order one make sure you get the updated version with the tap up top (not the bottom) for the boost tube.
If you run a boost line off it...I recommend getting an elbow fitting and pointing it towards the passenger side of the truck. That way your boost tube will not be in the way of the oil or fuel filter caps when you do routine maintenance.
I like the results w/ mine as well. I had already setup the boost probe so i didn't use the one on it but would agree it needs to be angeled to claer the filters. Local dyno/tuner shop (Dynojoe.com) felt it really did improve performance
