Zf 5 spd bellhousing pattern
Old Jul 4, 2007 | 07:15 PM
Jason6969's Avatar
Jason6969
hello i m looking to switch to a cummins diesel in my 1986 f -350 and was looking for a zf 5 spd to use for the conversion. my question is are the 351 and 460 patterns the same on the transmissions or are they different for every engine avalible.
Old Jul 4, 2007 | 08:00 PM
Dave Sponaugle's Avatar
Dave Sponaugle
All I can tell you on that is no gasser tranny will bolt to a 6.9 or 7.3 engine.
All diesel transmissions from the 83 6.9 thru the 2003 Power Stroke 7.3 will bolt up to any of the diesel IH motors.
Old Jul 4, 2007 | 09:08 PM
Brimmstone's Avatar
Brimmstone
302-351 windsor and 351 cleveland use the same pattern. 351m-400 429-460 use the same also. Diesel is in a family all to itself. I will have to check my book to make sure of the interchanges in bell housing designs. To make matters even more fun some 302s had there own pattern also.
Old Jul 4, 2007 | 10:44 PM
zigzkidz's Avatar
zigzkidz
destroked.com has an adapter if you need one to mount the bellhousing to the engine, fordcummins.com also has one but it requires you to cut part of the transmssion. Here's a link to a conversion website,
http://www.cummins-conversion.com/phpBB/index.php
tstewart78
Nov 17, 2016 09:00 AM
mountain dewd
Aug 23, 2016 03:50 AM
four-sixty-power
24
Apr 6, 2016 01:22 AM
5280
May 12, 2014 11:54 AM
76'Highboy
Nov 17, 2010 12:00 AM
