anybody use polyester primer
Old Jul 4, 2007 | 04:56 PM
1949f1's Avatar
1949f1
i am doing the body work on my 86 ranger.i was told about useing the polyester primer.i was told it will self level over scratch's in the paint and place's that have not been feather'd out.also you don't have to take the old cracked paint all the way to metal.just da it with about 80 grit.any truth to this stuff.
Old Jul 7, 2007 | 03:08 PM
1949f1's Avatar
1949f1
don't tell me nobody know's anything about polyester primer.need alittle help here
Old Jul 7, 2007 | 03:50 PM
jwtimme's Avatar
jwtimme
never herd of polyester primer
herd of polyuritane primer though; is this what you are talking about.
Old Jul 7, 2007 | 06:16 PM
mrl390's Avatar
mrl390
Hes probably talking about Polyurethane. We use 2K at work and block sand it before using surfacer over it. You can put it over sanded paint, primer, fiberglass or putty.
Old Jul 8, 2007 | 04:30 AM
roger dowty's Avatar
roger dowty
i've heard it referred to as polyester too...like a bad suit.
A good fill primer would be 2k as stated above and will fill in up to 180 grit scratches or so...and it's compatible with urethane paints which are the best.
Old Jul 8, 2007 | 07:54 AM
kenseth17's Avatar
kenseth17
Polyester primer (featherfill for example)is a primer that uses the same type of hardener bodyfiller does. Basically sprayable bodyfiller. It will fill a lot more then other primers, but you need a gun that can handle spraying it. I haven't really used it. I don't know if I'd take too many shortcuts and leave old cracked paint, or bad featheredges cause of too many layers of paint ect(shortcuts usually get you know where and often come back to bite you), but it has a lot of fill, heard even fills 36 grit scratches. If you have a pretty wavy panel that needs a lot of blocksanding and fill, polyester is probably the one to use. Try searching on hotrodders.com for polyester primer, I know its been discussed a few times. Here is just one thread
http://www.hotrodders.com/forum/poly...r+feather+fill
Old Jul 8, 2007 | 08:54 AM
whitecougar's Avatar
whitecougar
I used the polyester putty, first I've heard of the primer sounds expensive but would cut down on prep time tremendously.
Old Jul 8, 2007 | 01:26 PM
mikefender's Avatar
mikefender
I've been using alot of feather fill g2 lately, the big thing is to spray medium coats not full wet or it may not cure.
Old Jul 8, 2007 | 05:57 PM
1949f1's Avatar
1949f1
http://www.hotrodders.com/forum/polyester-primer-who-has-most-mils-per-coat-67968.html?highlight=polyester+primer+feather+fill
thank's kenseth17,it has factory paint on it but with alot of place's i had to sand to metal,and thank's for the web info.by the way,i like kenseth too.
Old Jul 9, 2007 | 11:57 AM
roger dowty
i'd seal the truck with epoxy primer before using any other primer. Give you a good solid base from which to work.
Raleigh1
Paint & Bodywork
Oct 11, 2013 11:47 PM
jvmcc
Paint & Bodywork
Aug 29, 2013 07:28 PM
pullinair
Nov 6, 2006 05:48 PM
onioncasserole
Paint & Bodywork
Feb 4, 2005 04:59 AM
turbosek2
Paint & Bodywork
Feb 23, 2003 07:42 AM
