Sponsored by: Auxito
fuel leak
Old Jul 3, 2007 | 04:39 PM
Rojuco's Avatar
Rojuco
fuel leak
97 F150 4.6L 4X4...If I fill up with gas as fast as the pump will pump gas leaks from the top of the fuel tank. I also get codes 1151 and 455. What should I be checking first? I need to get this fixed as my mother in law is getting tired of pumping my gas.
Old Jul 3, 2007 | 04:45 PM
jjlogue3's Avatar
jjlogue3
You might check to see if the filler hose that goes into the top of the tank hasn't popped loose it is held on by a screw type hose clamp.
Old Jul 3, 2007 | 04:49 PM
jjlogue3's Avatar
jjlogue3
And if I am not mistaken those are the codes it throws up when your gas cap is loose so I would look for a bad connection
Old Jul 3, 2007 | 04:53 PM
ranger88a's Avatar
ranger88a
Has anyone put a fuel pump in it recently?
MonArt60
Oct 31, 2014 01:45 PM
lsmcnabb
Oct 13, 2014 04:54 PM
Joejustatruck
Oct 24, 2012 11:49 AM
spkennyva
Dec 24, 2010 04:51 PM
coalminer78
Jul 18, 2005 09:37 PM
