Fuel pump leaking
Old Dec 24, 2010 | 02:00 PM
spkennyva's Avatar
spkennyva
Fuel pump leaking
Just found out that gas is leaking around my fuel pump. It doesn't appear that it is the fuel line, but not sure. Seems to be leaking from the pump itself. Is this a typical failure for these pumps?
'82 F250 351W
Thanks.
Old Dec 24, 2010 | 02:05 PM
Franklin2's Avatar
Franklin2
Yes, it can happen, and it can leak into the crankcase and put fuel in your oil, thinning it out. Pull the dipstick and see if the oil level is high.
Old Dec 24, 2010 | 02:21 PM
ctubutis's Avatar
ctubutis
Yes, it can happen, and it can leak into the crankcase....
Yes, that exact thing happened to me once:
https://www.ford-trucks.com/forums/7...crankcase.html
Old Dec 24, 2010 | 02:55 PM
spkennyva's Avatar
spkennyva
Thanks for the great feedback. Just checked and the oil level and is normal. No gas smell either. Guess I'm replacing the fuel pump.
Thanks again!
Old Dec 24, 2010 | 03:58 PM
spkennyva's Avatar
spkennyva
What replacement pump do you guys recommend? Go with an AC Delco, Carter, or what? I plan to stick to a standard replacement pump.
Old Dec 24, 2010 | 04:51 PM
ctubutis's Avatar
ctubutis
The one that leaked on me was from Napa and had lasted only around one year, I was
disappointed.
I would try to get a Motorcraft if you can find it but, outside of that, I just get whatever
available at the parts store.
Damifiknow
Oct 2, 2016 08:24 PM
therigwelder
Oct 2, 2016 12:34 AM
ahha-retired!
Apr 5, 2015 09:40 PM
Onus
Feb 9, 2012 08:40 AM
fordfan28
Aug 24, 2007 05:06 AM
