sooting under hood
Old Jul 3, 2007 | 01:09 AM
mndiesel's Avatar
mndiesel
sooting under hood
What would cause sooting on the front of my regulated return guage just in front of the turbo? Tom
Old Jul 3, 2007 | 03:46 AM
ron's power stroke's Avatar
ron's power stroke
sooting is caused by an exhaust leak..check around the up pipes where the donut's are...just behind the turbo..
Old Jul 3, 2007 | 07:36 AM
bdrummonds's Avatar
bdrummonds
is it sooting, or maybe a fine oily film? Rons right if it is sooting, but if it is a little oily, then it may be ccv gases coming out of a loose boot, or the o-rings on the doghouse may be gone.
Old Jul 3, 2007 | 11:36 AM
mndiesel's Avatar
mndiesel
the o-rings on the doghouse may be gone.[/QUOTE]
Bdrummonds,
What is the doghouse? Never heard it put that way before. Thanks Tom
Old Jul 3, 2007 | 12:35 PM
Izzy351's Avatar
Izzy351
I had one that was split, but it only created a slight oil leak -- no sooting that I noticed.
Old Jul 3, 2007 | 01:47 PM
bdrummonds's Avatar
bdrummonds
Bdrummonds,
What is the doghouse? Never heard it put that way before. Thanks Tom[/QUOTE]
Tom, the dog house I am refering to is the CCV dog house on the rear or the drivers side valve cover, there are two orings underneath it. If they are bad you can see some oily film, and smoke in your engine compartment. Now, it is not soot, like what would be on your finger if you touched the inside of your tail pipe, but it is a dust magnet. As Ron said earlier soot would come from an exhaust leak, if it is soot then check your v clamp on your down pipe, and also make sure there is no leak on the back of the turbo at the collector where your two up pipes meet.
Old Jul 3, 2007 | 10:27 PM
mndiesel's Avatar
mndiesel
bdrummonds,
thanks for the info I will check those tomorrow. Tom
