compression ratios
Old Jul 2, 2007 | 05:51 AM
68429f100's Avatar
68429f100
compression ratios
the name is jack i have a 68 f100 with a DOVE A 460 with 429 internals and DOVE C heads, i need to figure out what type of compression the heads have at stockdeck height. the motor is punched out 30 over with a compcams 584 588 lift and 240 246 duration at .050 hydraulic. also equipped is a edelbrock 750, and edelbrock rpm performer aluminum high rise intake and hedman headers with qtp electric cutouts. pushing power to the 750 is a marine grade electric pump from the stock tank ( i like it) the electric cutouts are followed by dual 40 series flowmasters and dump right behind the cab. power is transferred from the 429 to the c-6 and from the c-6 to a ford 9er in the rear.
Old Jul 2, 2007 | 07:02 AM
Ultramagdan's Avatar
Ultramagdan
Hello and Welcome!
I'm sure you'll get some help from the post you did in the F100 forum. I would also suggest the 460 engine forum. Either way you can't go wrong.
For local support and information be sure and checkout one of the CA chapters. They are located towards the bottom of the Forums list.
Good luck!
FEsfromhell
New Member Introductions
Feb 17, 2008 11:25 PM
dave3778
Mar 27, 2007 06:42 PM
donny ford
Jul 3, 2006 12:59 AM
frankenford06
Mar 16, 2006 06:42 PM
