replace a 292 with a 390???
Old Feb 17, 2008 | 10:32 PM
FEsfromhell's Avatar
FEsfromhell
Angry replace a 292 with a 390???
i just traded my 1965 ford for a 1955 ford both f100's... tho not to bad in the style department it is definatly laggin in the power area with its 292 Y block, and 1 bbl carb. i found out real quick how much more it costs to build a 292 rather than a 302 or an FE. i would prefer an FE since i have a 390 just sittin around. a 302 would be much cheaper to build but i am not to fermilier with the output on them since i have only owened big blocks and FE's...
now to the point... when i had my 352 that i tossed in a 390 crank and rods and a comp cam magnum cam with a 750 edelbrock and some how mannaged to get 12+ MPG with ported cobra jet heads... it is know around here as the 460 duster seeing how i never came close to loosing a race, tho i did loose to a 383 stroker (damn chevys). that build up cost me about $900 for all all that and ignition, wires, bearings, cam, carb, and so on, i know most parts in fes are inerchangeable such as cranks and heads so on....
now on a small block i can get one for free and i can rebuild it cheaper tho id like to know what it would take to keep up with my old 352 if i went this route with out being rediculs on gas way to expensive and i guess over all what it would take...
how involed would these be to swap and what would be the most cost enffeciant quickest best power builder??? i am in desperate need of your help if i could please get it it would be much appreciated thanks....
Old Feb 17, 2008 | 11:25 PM
Fomoko1's Avatar
Fomoko1
Welcome FEsfromhell.
Congrats on your new ride, one of my all time favorite is the mid 50`s Ford trucks.
To hear both sides of this debate drop into the Performance and General Engine Building forum: https://www.ford-trucks.com/forums/forum47/ and the 1948 - 1960 F1, F100 And Larger F-Series Trucks forum: https://www.ford-trucks.com/forums/forum41/
Be sure to drop your intro into the OR chapter as well: https://www.ford-trucks.com/forums/forum190/
jacob_9249
New Member Introductions
Jun 26, 2008 09:44 PM
angel.aprilia
Jun 14, 2008 10:54 PM
sterlingstein
Jan 9, 2008 09:25 PM
quadtrac
Feb 11, 2007 09:21 PM
MustangGT221
Jun 23, 2002 07:11 PM
