Open Loop/Closed Loop
Old Jul 1, 2007 | 07:23 PM
71LTD390's Avatar
71LTD390
I am currently trying to fix a poor fuel mileage problem on my '96 F150 5.0L 5 speed. I have another post here also.
This truck has OBD II. I have a scanner but am not quite sure of some of the readings I am getting.
My question is: How do you know if the truck is in open loop or closed loop?
Right now the scanner shows "Fuel System 1-N/A" and "Fuel System 2-N/A".
I thought Fuel System 1 should say "Open" or "Closed".
Please help. Thanks!
Old Jul 1, 2007 | 08:21 PM
water 5's Avatar
water 5
what brand is the scanner? did you have to fill out info of your truck in to the scanner?
Old Jul 1, 2007 | 09:18 PM
71LTD390's Avatar
71LTD390
It is an Actron scanner. Yes, I had to enter all of the truck's info. Year, Make, Model, Engine, etc.
If i'm not mistaken it used to say open or closed. Now it just displays N/A for them both. What does this mean?
Old Jul 2, 2007 | 08:33 PM
Phillip Guidry's Avatar
Phillip Guidry
Refer back to the scanners manual.....N/A could mean "Non-Apllicable" instead of "Non-Available"..... 1996.....the first "Full" year for OBD II......don't take much in context from what you see on the scanner.....go back to basics..you'll discover more.
Old Jul 2, 2007 | 08:38 PM
MustangGT221's Avatar
MustangGT221
What code numbers are you getting?
Old Jul 3, 2007 | 09:10 PM
71LTD390's Avatar
71LTD390
I can't remember the numbers but it was basically "Catalyst Efficiency Below Threshold".
Old Jul 5, 2007 | 07:11 AM
MustangGT221
That can mean anything from a bad cat...to a bad 02 sensor after the cat....to bad wiring to that o2 sensor....to a poor running condition.....
...Likely the first few options.
Old Jul 5, 2007 | 05:42 PM
71LTD390's Avatar
71LTD390
I will be replacing the O2 sensors shortly. The front two have been replaced about 60K miles ago....the rear one has never been replaced. Truck has 114K.
Does the rear sensor do anything other than "monitor" the cat? Or does it also control A/F ratio?
Old Jul 5, 2007 | 06:10 PM
73f100shortbed's Avatar
73f100shortbed
Rear O2 sensor monitors cat efficiency. If you are getting P0420 which is cat efficiency your converter is bad. Rear O2 sensor should detect zero oxygen past cat. If you get efficiency code you need a new converter. Might as well replace O2 sensors while in there.
Old Jul 5, 2007 | 09:25 PM
MustangGT221
The rear o2 sensor in some applications (probably including this one) will fine tune the A/F ratio, but the computer relies mainly on the front o2's for A/F.
Those codes never isolate one problem vs another....if the sensor isn't reading correctly....how can it tell you that the cat is actually bad?....it can't.
C F Industries
2004 - 2008 F150
May 4, 2011 05:56 PM
looking
Nov 21, 2007 06:44 AM
geezer95
1978 - 1996 Big Bronco
Apr 5, 2005 09:41 AM
seumas
1983 - 2012 Ranger & B-Series
Jun 13, 2004 07:40 AM
Duderoy
Feb 23, 2003 09:21 PM
