Breaker Breaker................
Old Jul 1, 2007 | 02:02 PM
Medic 66's Avatar
Medic 66
Anyone have any experience with glass-thru CB antenna's?
Old Jul 1, 2007 | 02:36 PM
ag30265's Avatar
ag30265
Give me a brand name and model number. I believe I know what your talkin bout but wanna be sure.
Oil filled or are you talkin bout the ones with the clear glass so you can see the coil?
Old Jul 1, 2007 | 03:14 PM
tewferford's Avatar
tewferford
Breaker breaker got a picture taker and the Smokey's at 43. It's that Japanese toy and truckers joy. That everyone calls CB.
Sorry I couldn't resist.
Carry on.
Old Jul 1, 2007 | 04:50 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Carry on.
Great song.
"The White Knight" by The Citizens Band.
Classic.
Old Jul 1, 2007 | 06:43 PM
Medic 66's Avatar
Medic 66
I am meaning like cell phone antenna's where one peiece is on the inside of the vehicle with the cord that screws on the end and then the other side goes outside the vehicle and "covers" the other end......
Bad description I know!!!
Old Jul 1, 2007 | 07:07 PM
wizzard351's Avatar
wizzard351
ive used them and they junk,not worth the money. if ya need a good antena and dont want to drill holes look at a wilson 1000,500,lil wil can all be had in magnet mount.depending on how many watts ya run. my wifes got a lil wil on her s-10 pushin 300 watts and it does real good but it max's the antena out its only rated for 300
Old Jul 1, 2007 | 08:12 PM
bhardy501's Avatar
bhardy501
Dont waste your time and money. You probably wouldnt be able to talk across the street. If you dont want to drill any holes they make mounts that will go under the bumper and then the coax can run under the vehicle and through the floor board. I have a 2 meter 5/8 wave Ham antenna mounted in the front corner of my truck bed. The only holes I have from it are the 3 screws that bolt the bracket to the inside lip of the bed. There is no difference in the way the antenna mounts and the coax is run between the ham antenna and a CB antenna. It actually looks like a CB antenna but will not operate on the 11 meter CB band. What ever antenna you go with make sure the SWR is below a 1.5:1. The best way to get a good set up is to go to a truck stop and find out where a good CB radio shop is. Your quality of signal getting out has more to do with a properly adjusted antenna than with having a big radio.
Old Jul 2, 2007 | 01:58 AM
Autoglass's Avatar
Autoglass
I've used a K-40 for several years without problems. Got it now on the PPG truck that I drive everyday.
Old Jul 2, 2007 | 02:38 AM
Snowbunny's Avatar
Snowbunny
I have a K-40 also... Mounts fast, on the edge of the hood (or trunk), and you don't have to drill anything, anywhere. Great range too!
Old Jul 2, 2007 | 10:39 AM
kw5413's Avatar
kw5413
Wow. I used the K-40 over 25 years ago. Can't believe they are still around.
It was a great antenna then, too.
Old Jul 2, 2007 | 12:38 PM
00BlueOvalRanger's Avatar
00BlueOvalRanger
I had a couple of K-40 antennas. The top of the coil (housing) cracks and water gets inside and shorts out.
The best antenna that I ever used was an 'Antenna Specialists' "Big Momma'!!!!!
I had one as a trunk mount and one as a magnet mount.
Ya know. . . I do NOT miss the 11 meter band. Not at all.
Old Jul 2, 2007 | 10:42 PM
ag30265's Avatar
ag30265
I have no experience with the style your reffering to. On my pickup I always ran a magnetic mount k-40 base with a 5 ft whip. I now run an 8 ft whip,spring mounted, with a high quality co-ax all pushed by a galaxy 88. In my heavy truck I run dual wilson 5000's into a three way with a galaxy 88 all pushed by a texas star 660.
The latter will TALK. It's unneeded but I like it and wasted all the money when I shouldn't have.
I have since found that a radio talks due to the ant. set-up, not the radio. It doesn't hurt to have a bigger radio but a stock cobra 25 will talk along way with a good ant. coax set up.
If you want no holes and a quick set up, take a magnetic base(inner coiled), a good ant. and make a ground wire to go from the bottom of the ant and run it with the coax and ground it somewhere. The ground will allow you to use a rag or towel(a thin one) under the base so the paint isn't harmed. Run that and attach to radio, and go to town.
Pappys53
Jul 16, 2017 09:27 PM
JoBoOtSdEfAyGo
20
Apr 1, 2007 09:38 PM
MisterCMK
25
Dec 22, 2003 09:46 AM
skuteman
Dec 20, 2003 08:12 PM
mk
56
May 15, 2003 09:37 PM
