battery cable ends
Old Jun 30, 2007 | 10:59 AM
ono_55's Avatar
ono_55
Go to welding shop and get some welding leads, then go to the battery store have them put the ends on.
Old Jun 30, 2007 | 12:03 PM
tndiesel's Avatar
tndiesel
I found a place (A&B Electrical). The guy said just remove the entire cable system and bring it in. He said he could make/build one identical. They sell heavy duty starters/cables/cable ends etc. He said he does this all the time. Also said it would probably cost around $100-$120 for the entire thing, is that a good price?
Old Jun 30, 2007 | 12:30 PM
tndiesel's Avatar
tndiesel
Since this is my first diesel can someone please tell me how (what order) to disconnect the entire battery cable system so I can take the entire thing to them to make me another one.
Thanks!
Old Jun 30, 2007 | 01:47 PM
tndiesel's Avatar
tndiesel
Bumpty, bump I'm trying to do this in the next two hrs. --Anyone?
Thanks!
Old Jun 30, 2007 | 02:05 PM
61 uni's Avatar
61 uni
Remove both negative cables first and then the positive. They sell large guage battery cablr by the foot at tractor supply. It should be your cheapest way to go. Did you drive back from florida with a c-clamp as a cable end?
Old Jun 30, 2007 | 02:07 PM
61 uni's Avatar
61 uni
Your engine compartment looks really rough. i'd change all of the fluids and filters. Your a senior user allready lol.
Old Jun 30, 2007 | 02:15 PM
tndiesel's Avatar
tndiesel
I did drive all the way back from Florida with the C-clamp, heck it starts great and on first crank.
Oil has about 900 miles on it and looks goodand clean
I know it's a little rough looking but I didn't buy it to have a show engine or truck.
I am going to change to a Tymar (spelling) air filter and get bigger tranny cooler.
I'm also going to change all hoses and coolant flush/change
Is there just the upper and lower coolant hoses?
What should I clean up engine with? Just some cleaner and a lot of shop rags or towels? Thanks for battery info.
Both negatives, then positives and then disconnect form the starter?
Old Jun 30, 2007 | 02:17 PM
tndiesel's Avatar
tndiesel
will they have both the positive and negative gauge? Or is it all the same?
Old Jun 30, 2007 | 02:52 PM
61 uni's Avatar
61 uni
Should be the same
I've never removed the cables from mine but allways remove the negative first
Old Jun 30, 2007 | 02:55 PM
61 uni's Avatar
61 uni
I used purple power cleaner on my tractor engine to clean it.
bkgeig
Dec 16, 2016 11:42 AM
ligito
Apr 10, 2015 08:00 PM
snaponprofile
May 7, 2011 08:43 PM
SLAYER1
Jan 5, 2010 06:29 PM
Sycostang67
Nov 4, 2009 02:39 AM
