HELP 89 7.3 Will Not Start
Old Jun 28, 2007 | 04:01 PM
Mad Max II's Avatar
Mad Max II
Question HELP 89 7.3 Will Not Start
Hey guys,
I have a friend that can't get his 89 7.3 started. Here is some history...
He had a low oil pressure problem so he pulled the eng to check the oil pump and bottom end bearings. He found a problem with the oil press reg and fixed it and put everything back together.
The truck started right up and he chased down a few leaks. On a test drive the truck stalled and he has not been able to get it started.
It looks like when the truck was sitting someone ripped off the fuel that was in the truck so he put 4 gal in each tank and still no start. He even tried starting fluid with no luck.
I recommended that he should take the fuel line going to the Injection Pump and make sure he is getting fuel. If fuel is getting to the pump then I asked him to loosen one of the fuel lines going to one of the injector and see if he is getting fuel to the injectors.
I am not very familiar with the old 7.3 so I am looking for some addition advise. I would think that when he tried the starting fluid it should of at least tried to fire.
Thanks for the help...
Barry
<!-- / message --><!-- sig -->
Old Jun 28, 2007 | 04:47 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
I would take the fuel filter off and fill it with fuel. Keep doing this until you get it running. Might take 2 or 3 times doing this. Also Your suggestion of loosening a fuel line from pump is good.
Old Jun 28, 2007 | 05:22 PM
David85's Avatar
David85
And as always, do not crank for more than 20 seconds and allow for 2 min. cooldown between each attempt.
You can also try cranking with the pedal pully depressed, this will increace the amount of fuel the IP sucks in helping it fire a little sooner. Once it starts to fire, back off, and it should start, but you may have to baby it for the first few seconds.
Old Jun 29, 2007 | 11:40 AM
460429_freak's Avatar
460429_freak
Originally Posted by Mad Max II
Hey guys,
Barry
nope if it not gettting fuel ether will not help ether was intended to help with diesel with out glow plugs
Old Jun 30, 2007 | 11:56 AM
Saigon's Avatar
Saigon
Swap the mechanical lift pump for an electrical pump (Facet or other) primes up everytime!
Robert Dingess
Jan 23, 2015 08:18 PM
honeyCANdew
Nov 8, 2012 02:44 AM
Sparkplugless
Sep 21, 2012 07:42 PM
bobdavis
Jun 5, 2007 09:34 AM
niteowl77
Nov 29, 2004 01:08 PM
