I Was Wondering My Farther Was Wanting To Up Grade His Ford To And Dursparck I Was Wondering Would He Have To Use An Ballisttic Restrior To Have It Worck Right.
No ballast resistor required for the Duraspark. You will need the distributor, module and wiring harness unless you're willing to make a home made harness. Do a search on this forum and you will find plenty of information on how to convert it.
If you have a donor vehicle for parts, you can grab the resistor with the coil and all the other parts you need to do the conversion. This is the best way to convert so you aren't missing anything. THEN you can consider upgrades, but my recommendation is to just go with the D.U.I ignition, which is self contained in the distributor with a high voltage coil, and easier to install. Look to the DUI sponsor to the left of your screen and follow the link. Worth every penny!
i have a question about the ballast resister, my truck has one but is disconnected. Is one reguired and if so is it hooked up to the postive wire to the coil or negative.
The Ballast resistor on the Duraspark II system is the Pink resistance wired coiming out of the igntion switch.
Oops!. I keep forgetting about that little pink wire!. You definitely need one when using all facory parts. I didn't need one on my Duraspark because I converted it to the HEI/TFI set up.
A resistor that has the property of increasing in resistance as current flowing through it increases, and decreasing in resistance as current decreases. Therefore the ballast resistor tends to maintain a constant current flowing through it, despite variations in applied voltage or changes in the rest of the circuit.
Newer cars don't require this resistor since the voltages are better regulated throughout each circuit.
I do not know the long term effects of not having the ballast resistor connected, but I'm sure the engineers had a reason for it at the time, on the older ignition systems. If it came with it, keep it. If upgrading to the newer, better ignition systems, then it is not needed.
The instructions (MSD) will tell you... The wire is a Nichrome wire that provides the resistance, when older ignitions used a seperate part that bolted to the firewall or maybe fender.
The old points ignitions couldn't take a constant 12 volts without burning out, so the resistor was used.
MSD has a 0.8 ohm resistor (PN 8214) if you don't have the wire anymore.
so did my 79 f100 302 w/Duraspark ignition, non points type come with the resistor wire?????? and yes I have the external ballast, just aint put it and the coil on yet
I believe it should have come with it, yes...Adding another resistor to it with the same value??? Might not change anything, but if something doesn't seem right then lose it.
Converting 1986 F150 XL 300 I-6 to DURASPARK, with some reading and searching these posts I've come up with using an application for a 1980 Bronco w/300 (distrubutor/carb/control box). Not having a donor vehicle yet so we have no harness or pink wire from harness...does the '86 have a resistor wire within the ignition harness or do we have to add a ballast resistor?...some posts I've read here mentioned using 2 ballast resistors in series...bare with me, this is all new to me.
