302 Flywheels..
Old Dec 19, 2002 | 05:24 PM
78ford100's Avatar
78ford100
302 Flywheels..
The way I understand it, the 302 from 86-95 used the 50oz. imbalance, right? No matter what the application? I had a guy try to tell me that a flywheel (with the 50oz. imbalance) off of an 86 truck wouldn't fit an 86 Marquis (motor). The Marquis is fuel injected, and is auto. In order to put it in my truck, I'll need a flywheel to fit it. The reason I want to go with a truck flywheel as opposed to one out of a mustang is clutch size, I'd like to stay with the 11" clutch. Thanks guys,
Justin
Old Dec 19, 2002 | 08:14 PM
Franklin2's Avatar
Franklin2
302 Flywheels..
All the 302's are 50oz inbalance after 82. The only issues I see are flywheel size/starter location. But I assume you will be using the truck bellhousing that is set-up for the large flywheel, so that should be ok. The only other issue will be the pilot bushing in the end of the crankshaft. An engine from a automatic doesn't have one. Check and make sure the crankshaft has a place for the pilot bushing, and install it. Hopefully it's already machined correctly for one.
Old Dec 19, 2002 | 09:15 PM
78ford100's Avatar
78ford100
302 Flywheels..
[updated:LAST EDITED ON 19-Dec-02 AT 10:24 PM (EST)]Yeah, I'll be using the truck bellhousing. Didn't the torque converters have a thing that fit into where the pilot bearing would be in the crank? It was that way on my mustang, anyway.
Old Dec 20, 2002 | 07:22 PM
Franklin2's Avatar
Franklin2
302 Flywheels..
You can check, but I don't think it's the right size for the tranny shaft without the proper bushing. Some of them have needle bearings.
Old Dec 22, 2002 | 04:14 PM
gamehunter's Avatar
gamehunter
302 Flywheels..
Automatic transmitions done have flywheels. They have FLEXPLATES. So, no, it wont work.
Old Dec 23, 2002 | 09:57 AM
EPNCSU2006's Avatar
EPNCSU2006
302 Flywheels..
[updated:LAST EDITED ON 23-Dec-02 AT 10:59 AM (EST)]He's switching the flexplate from the Marquis out for a truck flywheel for him to use with a manual transmission. I don't see any reason why it wouldn't work besides the pilot bearing thing on the end of the crank. I would think all of that would work though, I can't see Ford machining cranks differently for manual or auto tranny's.
Old Dec 23, 2002 | 08:20 PM
engineguy's Avatar
engineguy
302 Flywheels..
It should work fine, just put in a new crank bushing, and the proper bolts to match the flywheel(longer on a flywheel than a flexplate).:-X12
Old Dec 23, 2002 | 08:32 PM
engineguy's Avatar
engineguy
302 Flywheels..
rangerottis
May 23, 2014 03:57 PM
RA051126
Apr 27, 2011 04:24 PM
motorhead_83
Engine Swaps
Mar 26, 2004 09:53 AM
