EGR code and Zero Driveability problems?
Old Jun 27, 2007 | 01:59 PM
Green_Monster's Avatar
Green_Monster
Smile EGR code and Zero Driveability problems?
I know from time to time trucks will throw an odd code you clear it and it never comes back, keeping that in mind I was looking for some solid advice on my egr code.
Code P0401 is in my computer now and I am debating on:
The clean the egr and reinstall method ( 1- 2 hrs depending on how dirty) and hope that solves the problem (great post in the tech section very thorough but I have had little luck cleaning the egrs on gassers)
Replace with updated egr valve keep old one clean at my leisure to reinstall if (rather) when the code lights up again
Deleting the whole egr setup with the sct? and egr tube (this is my least approach just for the what if factor)
My truck is an '03 f350 with the 6.0 and overall I have had little problem with it
Old Jun 27, 2007 | 02:50 PM
npccpartsman's Avatar
npccpartsman
This is my vote. I however would get an up-pipe that takes the EGR cooler out of the exhaust stream, clean the EGR valve with CARB cleaner (not brake cleaner) and weld it shut. Have it programed out with the SCT and be done with it. Then you don't have to worry about the EGR codes if they happen.
Old Jun 27, 2007 | 02:57 PM
OZX1's Avatar
OZX1
Talking
My 03 kept throwing EGR codes (as read by my SCMT1704A), despite the installation of a brand new EGR valve. When I took it to Ford as a concern, my techs OBDCII reader read NO CODES! I took it home and read codes... I surmised that my reader was not so smart as his and called it good; unplugged the new EGR; drove happy. Maybe your reading an erroneous code too... I dunno?
Old Jun 27, 2007 | 03:11 PM
WishIhada7.3's Avatar
WishIhada7.3
unplugg it.........
Old Jun 28, 2007 | 02:28 PM
B-61 Bulldog's Avatar
B-61 Bulldog
Hey Green my truck has had EGR Problems before twice matter of fact
1st time it threw a 401 insuffecent flow no power what so ever & surged it was a EGR Valve then
2nd time it threw a 402 Excessive flow this time didnt surge BUT NO POWER & Almost died @ the light i was sitting@ the time
that time it was a DPFE Sensor
not sure if the 6.0 HAS A DPFE Sensor ya might check your dealer or mechanic to see if it has a DPFE Sensor also that was my colpurt the last time
hope this helps
Bulldog
Old Jun 28, 2007 | 05:40 PM
Green_Monster
ok sounds like I will probably dump the egr when I can get the sct($$$), right now I am going to go with the clean and clear code method. Hopefully not replace but we shall see.
oh yeah whats a dpfe?
thanks for the input
Old Jun 28, 2007 | 06:22 PM
blackhat620's Avatar
blackhat620
Differential Pressure Feedback EGR system. It is not installed on the 6.0 or 6.4 PSD.
It is installed on some Ford gas engine vehicles. The DPFE measures the flow throught the EGR valve and sends this info to the PCM so that the EGR valve can be better regulated by the PCM for given load and driving conditions.
Old Jun 29, 2007 | 08:44 PM
B-61 Bulldog
ok wasnt sure weather the 6.0 had the DPFE Sensor or not
later
bulldog
Old Jun 30, 2007 | 07:35 AM
BowTieHatr's Avatar
BowTieHatr
hey green, what kind of mods do you have? any aftermarket filters?
Old Jun 30, 2007 | 04:13 PM
Green_Monster
sorrry foir the delay benn workin my A$$ off
Bowtie - my truck is 100% stock right now, as mucjh as I owul dlike to play with it it is my daily driver and I am looking to improve the reliability as well as pulling some more torque and HP out of it for pulling trailers without breaking the bank or the truck.
In other words I ain't rich
Seriously just looking to be cautious and do as much diagnosing and repairs my self to keep costs down, which leads to my next ??
I want to get an aftermarket scan toolfor my truck ( as well as my wifes Ch3^y) I am torn between an sct xcal setup ( that is vehicle specific right?) or say an actron type scan tool that will help me diagnose etc. I have done some reading here but still have ???
Everyone Thanks for all the info etc
Old Jun 30, 2007 | 04:47 PM
BowTieHatr's Avatar
BowTieHatr
reason why i asked about the mods, is because on the 03s aftermarket air filters will cause egr codes cause it plays with the maf readings. giving certain situtions, egr codes can and will be set.
biggreybox
Mar 14, 2011 10:57 AM
Bert01F150
3.8 & 4.2L V6
Jun 29, 2009 10:23 PM
RGrimes
1997 - 2003 F150
Feb 7, 2006 12:36 PM
e-manfive
Nov 27, 2004 07:31 AM
robask
Oct 24, 2001 11:20 PM
