89 f350 ??????????
Old Jul 21, 2007 | 03:22 AM
  #31
tjc transport's Avatar
tjc transport
i ain't rite
if i remember corectly, there is only 1 ZF that was offered with the diesel
Old Jul 21, 2007 | 11:03 AM
  #32
Dave Sponaugle's Avatar
Dave Sponaugle
One five speed, two different versions.
S 42 or S 47.
Three possible different gear ratios in each version.
Old Jul 21, 2007 | 10:19 PM
  #33
a711112a's Avatar
a711112a
how do you tell them apart
Old Jul 22, 2007 | 10:36 AM
  #34
Dave Sponaugle
The ID tag if it is still there is on the drivers side.
Look in the shifter area about 1/2 way up the side of the transmission for the tag.
Old Jul 22, 2007 | 12:03 PM
  #35
a711112a's Avatar
a711112a
thanks dave
Old Jul 23, 2007 | 01:32 PM
  #36
Dave7.3's Avatar
Dave7.3
S 42 or S 47.
Any chance you have the gear ratios on hand for both versions?
Old Jul 23, 2007 | 11:01 PM
  #37
Dave Sponaugle
ZF S 5 - 42
Max Torque 600nm 580nm
433 Ft Lbs 419 Ft Lbs
1 4.65 5.72
2 2.60 2.94
3 1.53 1.61
4 1.00 1.00
5 .77 .76
R 4.35 5.24
ZF S 5 - 47
Torque 640nm or 462 Ft Lbs
1 5.72 5.08 4.14
2 2.94 2.61 2.37
3 1.61 1.53 1.42
4 1.00 1.00 1.00
5 .76 .77 .77
R 5.24 4.66 3.79
Sorry for the columns being smashed together.
It does that every time I try to post this.
Copy and paste to notepad, then you can seperate the columns with a tab key stroke.
Old Jul 24, 2007 | 11:23 PM
  #38
Dave7.3's Avatar
Dave7.3
Thank you very much Dave. Looked at the tags and it seems I have the S-47 model. Hopefully it will match up alright with the 3.55 ring and pinion I have on order
Old Jul 25, 2007 | 05:29 PM
  #39
Jake S's Avatar
Jake S
I have a zf s5-42 with 4.14, 2.37, 1.42, 1, .77. Acording to my ford service book that is the only option that ford used for the diesels until the s5-47 came out. The gas version is the 5.72 first gear.
Old Aug 2, 2007 | 07:41 PM
  #40
a711112a's Avatar
a711112a
i have the zf 42 .77 overdrive
Old Aug 2, 2007 | 07:50 PM
  #41
a711112a's Avatar
a711112a
i found a 86 6.9 with the p code trans will this work with my 89 zf5 speed do i kneed to change fly wheels what can i use off my engion to get the doner to work
ther is no starter on the 6.9 will the 7.3 one work
thanks guys
J
Old Aug 9, 2007 | 08:04 PM
  #42
a711112a's Avatar
a711112a
are these engions internally balenced or externally can i use the 7.3 fly wheel on the 6.9
Old Aug 9, 2007 | 08:13 PM
  #43
Jake S's Avatar
Jake S
The starter and flywheel will work with both motors. The flywheels and clutch tend to follow the trans., so use the one from the zf.
Old Aug 9, 2007 | 08:43 PM
  #44
a711112a's Avatar
a711112a
thanks i will do that
now i have to get the starter fixed it was damaged when the 7.3 blew a nice hole through the block and oil pan i cant wait to se what came apart in there
Old Sep 18, 2007 | 10:24 PM
  #45
a711112a's Avatar
a711112a
tested the 6.9 used ether on it not good! at the worst i think i blew the head gaskets hope fully that is all. any way going to pull it apart and check all the clearance's. does any one know how much a 86 6.9 weighs? so i can build a engine stand strong enough to hold it. will a 7.3 injection pump fit it? I'm thinking i want to use as much of the 89 7.3 parts as possible like the 7.3 glow plugs and pump and injectors that way I'm not changing the wiring on the truck.
thanks j
