windsor block cleavland heads
Old Jan 30, 2003 | 11:09 PM
speedkingf100's Avatar
speedkingf100
I have found a single plane 351 clevland manifold for the 4v in the Canadian High performance discount catalalogue for 389.95 canadian dollars does that sound good
Steve
Old Jan 31, 2003 | 03:11 AM
blie's Avatar
blie
Thanks for your feed back. I have bought a lot of stuff through canadian high performance in Prince George. I do have access to spacer plates that would allow me us a cleavland manifold the only problem with using a cleavland manifold is that it is dry. I don't want to drill holes through my original boss 302 heads. I am going to buy the B&A track boss for the 4v listed above. The only problem with that one is that the runners are still alot smaller. I can still swap manifolds and try the dyno between that one and my boss intake with spacers to see what is better. I am definitely going to buy the hiborn injection set up for it this year. Won't be till later in the summer though. I will bolt it on down in The US and drive it over saving me duty. shhhhhh don't tell anyone. It is a three piece set up I found out so I don't even need my spacer plates and it has the option of pulling water out of the intake flange. It looks awesome but It will flow amazing amounts of air. Anyone wants to look at it they have a website. I encourage anyone to look at it the have injection set ups for almost any motor. All the best thanks for all your help Bob
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
