temp gauge problems
Old Jun 26, 2007 | 12:24 PM
bgcustoms's Avatar
bgcustoms
temp gauge problems
I have a 96 ranger 4.0 auto 2wd. temp gauge would read for while then drop. it did this for about a month, then stoped all together. I did chang the sending unit. That made no change, I am geussing the problem is going to electrical. has any one else delt with this. any info would be great. thanks Brian
Old Jun 26, 2007 | 05:14 PM
pawpaw's Avatar
pawpaw
Welcome o FTE.
With the ignition to run, will the temp gauge read full scale HOT when the temp sendors wire is shorted to ground????
If it does, suspect the sendor, or a poor ground connection to the engine block.
If not suspect the connectors wire crimp, the wire, or temp gauge.
Let us know what you find.
