Gooseneck hitch
Gooseneck hitch
I have an 06 F-250 short box. Looking to get a gooseneck hitch installed. I have a B&W hide-a-way hitch priced at $581 installed. My question is this: Are there any brands better than the other? Lastly, is this a good price? Can i do better? My only requirement is that it can flip, slide, or hide so i can have a smooth bed.
Half and hour to install??? It took me half and hour to cut the hole in my bed! I measured and remeasured and did a lot of thinking before making the cut. Sure didn't want to mess up my new truck.
BTW, I was too cheap to buy a hole saw. I used my Bosch jig saw to make the cut then filed the burrs, worked great.
check out the B&W website. they have pdf's available of all the installation instructions.
http://www.turnoverball.com/
application guide
http://www.turnoverball.com/turnover/applications.htm
99-07, SB & LB, Ford Super Duty, 3/4T & 1 Ton, fits with most aftermarket airbags
Model 1105R, can be mounted 3.5" or 6.5" from center of axle to center of ball
http://www.turnoverball.com/downloads/pdf/1105R.pdf
99-2008, SB & LB, Ford Super Duty, 3/4T & 1 Ton, and 08 F450 with factory installed bed
Model 1108R, mounting is 4.5" from center of axle to center of ball (NOTE: all measurements place ball in front of axle)
http://www.turnoverball.com/downloads/pdf/1108R.pdf
application guide
When you cut the hole...depending on your bed and your likes...you will have two choices on where to cut the hole, (with a B&W), 43 or 46 inches. The 43 will put the hitch right over the rear axle, the 46 will put it to the front of the axle by 3 inches. Depends on your trailer too. Also, if you go with a 4inch hole saw, you will have about a 1/4 to 1/2 gap around the hitch plate that sticks up in the bed. I went with a 3 1/2 and it is a snug fit with very little gap. Just looks cleaner to me. But you have to be VERY careful when measuring and cutting for the hole. You get less room for error with a smaller hole saw. The instructions called for the 4 inch, but my buddy said to go with the 3 1/2, (or the 3 3/4 can't remember which), for a better look.
I've used the Drawtite 'Hide a goose" hitch on my last three trucks. It appears to be the exact same product as the B&W from the photo's and descriptions. Capacities are the same, everything appears to be the same.
I too installed my own, and am in the process of transfering the hitch from my '05 F350 to my '08 F450.
Scott
Scott
thendrix
01-06-2017 09:28 PM
Caper2012
Fifth Wheel & Gooseneck RV Towing
04-30-2014 09:08 PM
