External parking brake
Old Jun 27, 2007 | 03:56 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by luke-gr
One of the guys at the parts store was telling me about an old car that had an external parking brake.....it was left on and that, coupled with a tranny seal leak, started a fire.
Chrysler product 1940/54.
Old Apr 9, 2011 | 12:42 PM
luke-gr's Avatar
luke-gr
Any chance someone could point me in the right direction of a parking brake drum for this truck. The drum is 8"x2". Bolt pattern looks to be about a 3.75" circle (+/-).
Drum has very uneven wear on it (dished out) and parking brake has already quit working. If I cant find one at a reasonable price I'll just re-adjust the brake lining, but I hate to wear out the lining on a surface that is not flat.
Old Apr 11, 2013 | 01:44 PM
luke-gr's Avatar
luke-gr
Can this external brake drum be welded up and turned down back to spec? I assume so. See last post. The center of the drum is worn much more than the outer edges so the brake lining is only touching on the outer edges. And I left it on once.
The nut on top of tranny that holds shifter in place loosened up so I had to take the floor access panel out. Good time to get this fixed. Unless I hear otherwise I'll get it out and take by welding shop.
Thanks for any advice.
Old Apr 24, 2013 | 01:46 PM
luke-gr's Avatar
luke-gr
Welding shop said he thinks it is tempered and was afraid it would crack/ warp. Even if not, he said it may be in the neighborhood of $120 because of the time involved welding. My auto parts guy suggested me welding it using a skip pattern down the middle where it is dished out. That would work well helping it grab for the parking brake but I would feel better about having it built back up and machined flat for an emergency brake.
I may try the welding then just have machine shop turn it for me on the lathe. I can spend the time to make sure I dont overheat.
Anybody know where one of these for a 64 f350 might be?
Old Apr 24, 2013 | 04:58 PM
NumberDummy
8D-2614 .. 8" x 2" Parking Brake Drum / Obsolete
B7Y-2648-A .. 8" x 2" Parking Brake Shoe & Lining Kit / Obsolete
No Ford Dealer or obsolete parts vendor has any.
Old Apr 25, 2013 | 02:55 PM
luke-gr's Avatar
luke-gr
Thank you, ND. I had looked up the part number in my manual and looks to be a fairly unique part. Have looked from time to time on Ebay and no luck. I'll proceed with welding and see if I can improve my situation.
Old Apr 25, 2013 | 04:03 PM
Blackwaterforge's Avatar
Blackwaterforge
These brakes are still used on medium duty trucks.
A truck shop should be able to help.
jcoy405
18
Apr 30, 2026 09:30 AM
luke-gr
16
Jun 29, 2016 07:38 AM
Luke Guihan
1978 - 1996 Big Bronco
Jun 21, 2016 12:08 AM
jcoy405
Feb 22, 2016 10:39 PM
ExcursionBoy1984
Feb 2, 2010 10:50 PM
