Need some help. I have a 48 to 50 F6 COE truck. I cant seem to find the vin on the frame or the cab. Where is it suppose to be exactly? Thanks for any help.
Welcome to FTE
The Patent Plate aka VIN plate is located inside the glove box door. My reference for 1948/52 says the serial number (VIN) is also located adjacent to the steering box, stamped on the frame rail.
I have a 55 effie and my vin plate was mounted on the glove box door. I looked under the hood and on the doors for it. I just happened to open the glove box and there it was.
I have found one number on the drivers framerail almost by the front bumper on the outside of the frame. It reads 7R8WH and then below it reads 5016. Really don't know what to make of this.
That's whats odd - that position is for the year. Normally an 8 or 9.
The R in the vin is for the V8.
As the new line of trucks started rolling thru tho, we've seen all kinds of exceptions. My best guess - and thats all it is - the stamper grabbed the 7 instead of the 8 like he had been doing for a whole year before. The serial string is low enough that this points to a January truck.
