Sponsored by: Real Truck
Installing reverse sensors
Old Jun 25, 2007 | 07:31 PM
Ford850's Avatar
Ford850
Has anyone installed the Ford factory reverse sensors on there older super duties. If is, how much work will it take and where can I buy a complete kit?
Thanks
Old Jun 26, 2007 | 05:54 AM
Exposed's Avatar
Exposed
Backup Sensors...
Save yourself a ton of money and buy one of the after markets ones from
Backup Sensors on the web. I looked at adding on my 2008 F-550. It was going to cost $100/per sensor and $130 for the box connecting to the PCM. This only gives you a beeper as you get close. I bought one of the back-up sensor system with wireless LED display.. It is slick. No wiring to the cab and comes with a LCD read out on distance both sides and beeper. Cost is $100.... I figured even if it did not last, throw away and buy another one...
It even comes with a hole saw for the holes...
It works great.......
Back Up Sensors site
http://www.backupsensors.net/
Pictures of installed on my F-550
http://www.ccb-design.com/Photograph...r/IMG_5159.JPG
Old Jun 26, 2007 | 08:42 PM
ReAX's Avatar
ReAX
I have done Echomaster's system in the past. Go aftermarket, there are alot of good alternatives that are cheaper than OEM.
Old Jun 26, 2007 | 10:27 PM
RACERX7775's Avatar
RACERX7775
anyone install them on the front bumper and have them hooked up so they turn on when the truck is shifted into drive??
Old Jun 26, 2007 | 10:48 PM
ReAX's Avatar
ReAX
That's an interesting Idea. It would be similar to that highend car collision alert system. It should work, just you would need to play with the angle the sensor sits at.
Old Jun 26, 2007 | 11:08 PM
RACERX7775's Avatar
RACERX7775
not really, the sensors would be straight because the front bumper isnt on the angle of the rear one is.
Morrisnes
New Member Introductions
Nov 4, 2014 02:13 PM
edjunior
Jan 7, 2012 09:02 PM
glruff
Dec 2, 2008 03:06 AM
va_tr1
Oct 4, 2005 06:44 PM
knuckles
Jul 11, 2001 11:13 PM
