Block Numbers Help~!!!!!!!!
Jun 25, 2007 | 03:44 PM
anyone got the numbers that came on a 351w so i can id on in a junkyard?? or a web site i can get them i wanna rebuild one.
Jun 25, 2007 | 07:38 PM
Where on the block would these numbers be ???
I have an 86 Box Truck with a 351 Windsor I think.
.......UPDATE........
Maybe I don't have a windsor.
Just read in another thread that a Windsor has 6 valve cover bolts and an M has 8.
I think I have 8.
Jun 26, 2007 | 01:42 AM
On the side of the block down by the starter.
The Original would have been either
C9OE-6015-A
or
maybe
C9AE-6015-A
Besides a Firing order that starts with 1-3-7-.
The Windsor has a Wet Intake .
http://boxwrench.net/specs/ford_302_351W.htm
70's E-series Vans will have them in them
Jun 26, 2007 | 08:41 AM
I think I have 8.
The only 351 available after 1982 was the windsor. The M stopped in 82. If you have 8 bolt valve covers then you most likely have a 460 not a 351.
Jun 26, 2007 | 12:08 PM
C9OE-6015-A
or
maybe
C9AE-6015-A
so what would be the better numbers? the c90e-6015-1 or c9ae-6015-a what block would be worth having if i could pick between the 2?
Jun 26, 2007 | 06:08 PM
Quote:
Not that either - 429/460 have 7 valve cover bolts. I'd guess somebody put in a C or M in that box truck.
Jun 26, 2007 | 06:25 PM
Woops..............
I just ran up to where I park it and I have 6 bolts on each cover, and Vin says it's a 351, so I guess it's a windsor.
I have the cabin cover off the engine and can see above the starter but it's a little oily.
I will try to flush it with brake cleaner tommorrow and see if I can find some numbers.
Jun 27, 2007 | 05:54 PM
Quote:
so what block numbers would be better to look for ?? all the other info is great but still need to know is one better then the other one make more power stock or is one stronger to use when building a stock/mild engine??
Jun 27, 2007 | 06:50 PM
I think he just wasn't sure if the number was C90E or C9AE.
I checked mine today but couldn't find a number, but I didn't look too good because it was so hot out........sorry.
Jun 27, 2007 | 09:13 PM
You are correct.
I don't have my Windsor book handy.
I would look for a C9OE-6015-B (BA)
The 69-70 were a stronger block.
The newer ones are light weight and I think they had a new design number in 1983. ....E3AE -6015 BA
EDIT:
Okay I found this.
351W-1971-1974 = D2AE-6015-BA
351W-1971-1974 = D4AE-6015-AA
351W-1975- 1981 - D4AE-60150DA
David K
Apr 15, 2024 09:08 PM
hickory1991
22
May 26, 2022 06:21 AM
dentside owner
May 13, 2017 03:34 PM
chukar
Feb 26, 2017 07:43 PM
Daltonsheets1995
Jun 1, 2012 01:17 PM
351 ,
351w ,
60151 ,
c90e ,
c90e6015b ,
c9ae6015 ,
c9ae6015a ,
c9ae6015b ,
c9oe60151 ,
c9oe6015a ,
c9oe6015b ,
d4ae6015aa ,
e3ae6015ba ,
ford ,
windsor
