Sponsored by: Real Truck
Trailer Brake Control
Old Jun 25, 2007 | 02:57 PM
EaTmYtAiLpIpEs's Avatar
EaTmYtAiLpIpEs
I was told the thing under the dash in the center of it covered with the black case i have to wire the wiring for the brake control module to. The part number of it is 4L3T-15A416-AB. Can someone tell me what it owuld involve. I haven't purchased the item yet but i am gonna have to. it is only $20 so.
Old Jun 25, 2007 | 03:20 PM
DonJames's Avatar
DonJames
What year & model vehicle you got? Installing factory 'TowCommand' or an aftermarket TBC (Trailer Brake Controller) like the Prodigy?
Old Jun 25, 2007 | 04:13 PM
EaTmYtAiLpIpEs
it is a 2003 ford f250. it is not aftermarket it is a ford product. it is oem. but idk if it came with tow option. it has a reciever hitch but that could have been put on at any time.
This auction is for a NEW Ford OEM brake controller harness as pictured. This part number 4L3T-15A416-AB will fit most F150 F250 and F350 with the trailer tow option
Old Jun 25, 2007 | 04:33 PM
Beerstalker's Avatar
Beerstalker
Do you have a link to the auction? If you are talking about what I think you are, that is about $12 too much.
Old Jun 25, 2007 | 04:54 PM
Green_Dually's Avatar
Green_Dually
If all you need is the harness,i have a spare i can give you.
Old Jun 25, 2007 | 05:00 PM
EaTmYtAiLpIpEs
welll where would the harness come up through the cab area where could i find it if there is one here is the link to the auction
http://cgi.ebay.com/ebaymotors/ws/eB...2670661&rd=1,1
Old Jun 25, 2007 | 05:08 PM
Green_Dually
The harness should have come with the truck.But the other end where the harness plugs into,should be under the dash.Pull the cover out from under the steering wheel.(the one with the 4 plastic locks) then when you have that off look over to the right,the plug will be clipped to a cross member.
Old Jun 25, 2007 | 06:04 PM
Beerstalker
I have a spare one of those too if you need it. You should be able to get one at just about any trailer equipment store though for less than $10. Also, what kind of brake controller are you installing. Tekonsha makes a harness that plugs right into the truck and the prodigy without even splicing anything and I think it's around $10 too.
Just noticed the 05-07 one is different so mine won't work for you, but here is a link to one for $10.
http://www.etrailer.com/pc-BC~18260.htm
Old Jun 25, 2007 | 07:58 PM
DetailerDave's Avatar
DetailerDave
Most aftermarket trailer brake controllers have the correct plug already installed for your truck.
But I looked, and I have the same part, made by Hoppy, that will fit your truck. Somehow I got an extra one. www dot trailerwiring dot com. Products, support, lookup by part number.
Hoppy PN 47705
You can have it for the price of postage from Delaware.
Old Jun 25, 2007 | 08:03 PM
DetailerDave
You only need this harness if you are installing an electric brake controller. You don't need it if you are using a flat 4 wiring connector at the back of the truck.
rjjastone
Jan 31, 2017 12:59 PM
awq134
2009 - 2014 F150
Dec 25, 2014 01:50 PM
Misky6.0
Dec 20, 2012 11:06 AM
5Rangers
Jul 25, 2011 09:42 PM
BaitGuru
May 12, 2010 11:14 AM
