Modular V10 (6.8l)
Please help we're stranded!!!!!!!!!!!!!!
Old Jun 26, 2007 | 02:58 PM
  #31
TD3619's Avatar
TD3619
Unhappy
Just got the word that the tank was full of rust and needed to be replaced, hard to imagine with ony 6000 miles. They are going to replace the tank and filter and hopefully nothing got to the injectors. They said they would have the tank by late tomorrow so all we can do is hope for the best and hopefully they'll have it done seeing we have to be in Norwalk,Ohio by Friday morning for the NHRA Nationals and from there we will venture on up in to Western New York to see the family.
Old Jun 26, 2007 | 03:14 PM
  #32
arctic y block's Avatar
arctic y block
Good luck. Keep us posted. And above all else, enjoy your trip the best ya can. Trips can be boring and ya don't get to meet new folks unless ya have some problems.
Old Jun 26, 2007 | 04:12 PM
  #33
krewat's Avatar
krewat
FTE Leadership Emeritus
TD3619, good luck with everything!
Funny, the F-series tank is plastic.
Isn't it the F53 a plastic tank too?
Old Jun 26, 2007 | 04:35 PM
  #34
arctic y block
I would think it was plastic as well. Did ya see the tank? Or will they let ya TD3619? I have fixed many a rusty steel tank by knocking all the rust out that I could. Rise them with Ospho. Than coat the inside with a sealant that i get from a marine supply store for that purpose.
Old Jun 26, 2007 | 04:40 PM
  #35
krewat's Avatar
krewat
PM me more about this sealant, like brand-name...
Old Jun 26, 2007 | 04:52 PM
  #36
arctic y block
It's a fuel resistant rubber type paint that ya pore in the tank and work it around by rocking the tank in yer hands. It was designed for the 6 gallon steel boat tanks. I can't remember the name. I'll try to remember to stop by the marine store the next trip to town. Maybe we can Google it. If I hear the name I'll remember it. Duh! that sounds kinda lame eh.
Old Jun 26, 2007 | 06:01 PM
  #37
Monsta's Avatar
Monsta
Sit. Stay.
Motorcycles use a product called KREEM. I imagine it comes in larger quantities than on that link.
Boy, it sounds like this fella is gettin' taken...
Old Jun 26, 2007 | 06:22 PM
  #38
arctic y block
Kreem would be similar and do the same thing. I'll call the Marina in the AM and ask them what they got.
Old Jun 26, 2007 | 08:20 PM
  #39
TD3619's Avatar
TD3619
He told me the tank was rusted real bad down around where the fuel pump sits. Regardless the new one is on it's way from Nashville should be here tomorrow and hopefully have us back on the road shortly there after! I'll be posting back shortly to let ya know how we make out! Have a great night guys!
Old Jun 26, 2007 | 08:47 PM
  #40
MARTYSTOWRIG's Avatar
MARTYSTOWRIG
Wow!! Rusted tank? WHODATHUNK?
Old Jun 26, 2007 | 09:23 PM
  #41
Fredvon4's Avatar
Fredvon4
Yes especially since every one of the Ford tanks I have had on a F series, E series, class A and Class C and even on the F53 chassis were plastic.... I imagine the original owner could have replaced the tank with a larger steel tank....??? very curious...
However it is entirely possible to have rust from the in tank pump pickup assy or from the filler neck or even a bad load of crappy rusty bottom dredges from a old in ground tank on the back roads
By the way I invest in steel tank coating called Kreem on every one of my boats and motorcycles since the early 70s...good stuff...but would be real expensive liner for a 38 gallon fuel cell...not to mention a real pain to spin and swirl coat the entire inside... biggest tank I ever did was the 12 gallon diesel tank on my 77 Rabbit/Golf
Old Jun 26, 2007 | 09:54 PM
  #42
poppie's Avatar
poppie
Is it possible the RV mfg put steel tank's on to give you a longer range of travel fillup to fillup,most P/U'S that size carry 38 gal, not going to get you vary far @ 6-9 MPG, if this is a class C it would carry 50-75 gal ,a class A would carry 75-100 or more,one more time,all of you that let anything sit for a long time,put conditioner in the tank and FILL THE THING UP!!!!, drive the air OUT, they sweat inside when they are partly empty and the tank will rust ,I have a 1958 John Deere 720 gas tractor my dad bought "new". back in Illinois when we farmed up there,we have it in Florida at our KOA campground for the past 7 years after selling the farm and buying the park,in florida it's a LOT more humid than in Illinois and the gas tank rusted and pluged the setiment bowl straner,took the tank to a radiator shop in Gainsville and he boiled the tank out and sealed it with some black stuff,it's been 3 year's and NO more rust!!!!said he did this to motorcycle's/car's and truck's but mine was the 1st tractor,it hold's27 gal's i think but never fill it up,the gas would get old even with condtioner as we drive it only about 10-15 hr's a year.
Old Jun 27, 2007 | 03:37 AM
  #43
goldendagger's Avatar
goldendagger
everything i drive has high pressure when releshing the gas cap.....
Old Jun 27, 2007 | 06:33 AM
  #44
poppie's Avatar
poppie
And ????,what is the high pressure made up of (air) example,diesel's will grow alge in the fuel tank when setting for several months and part of that issue is moisture in the tank,hell when i lived up north we used a product called (HEAT) in the gas to prevent gas line freeze up in the winter,anyone remember that stuff,and it worked,water is heaver than gas and will settle in the low spot's of the gas line and freeze up blocking the line,tank's that are only partly full WILL SWEAT,and if made of steel WILL RUST, the exception being plastic tank's,BUT you will still have the moisture issue which can not be good for the pump and injector's.
Old Jun 27, 2007 | 08:47 AM
  #45
goldendagger
high pressure
he was making a point that he thought there was too much pressure at his tanks cap when opening, causing some of his problems. i was just trying to verify that this is normal esp. w/todays fuel systems.....he doesn't have a oil burner, it was a gas coach.
