Modular V10 (6.8l)
Please help we're stranded!!!!!!!!!!!!!!
Old Jun 25, 2007 | 04:17 PM
MARTYSTOWRIG's Avatar
MARTYSTOWRIG
Clearly Fuel Starved. Filter, Plugs, And Injector Checks.
That Would Be My Sequence
Old Jun 25, 2007 | 06:22 PM
TD3619's Avatar
TD3619
Well thanks for all the replies, go it in to a RV repair shop this morning and they basically did another diagnostic test and determined that three plugs were misfiring. They put in some stuff called c-foam or something like in the tank and said it was bad gas. Got back on the road and made it about 100 miles to Birmingham and it started doing it again. We just got it hauled to another Dealership that Ford referred us to do the repairs. They told us that they were going to change the filter and drop the tank and flush it to make sure there is nothing is going on there. Are these tanks polyethylene or steel. I'm at a lost for words really.
Old Jun 25, 2007 | 06:54 PM
arctic y block's Avatar
arctic y block
I don't know what kind of tank it has. Could be either. Did ya try running it down the road with the gas cap loose?
Old Jun 25, 2007 | 06:56 PM
arctic y block
How can it be bad gas? Ya said ya refilled the tank so the majority of the fuel would have been replaced. That's not to say that there isn't gunk in the tank.
Old Jun 25, 2007 | 07:02 PM
arctic y block
Old Jun 25, 2007 | 07:03 PM
TD3619's Avatar
TD3619
We did try loosening the cap and it did it after about 25 miles of driving, like I said I'm clueless when it comes to these newer vehicles. It had roughly 1/4 tank of fuel when we refueled and seeing I'm no mechanic I can't really disagree with the guy seeing they deal with this stuff on a regular basis.
Old Jun 25, 2007 | 07:17 PM
arctic y block
Ya may have had bad gas to start with that fouled the plugs and plugged the filter. Cleaning the tank is not a bad idea. But with 3/4 of a tank of new gas and C foam I would think the gas is fine. I'd be mad if they say they threw away a 100 dollars worth of good gas. I would bet that after they refill yer tank and charge ya for the new fuel they will use yours. Granted there may be gunk in the tank. but once the fuel is drained and settles it should be fine. But if ya can afford it the new fuel will give ya peace of mind.
Old Jun 25, 2007 | 08:22 PM
MARTYSTOWRIG
After 100 miles it messed up again?
wierd!!!..
I wonder if................................................ .......
the gas was ok but the filter did not stop all of the gunk or filter itself caused the gunk to flow up to the injectors? I don't mean a dirty tank, but a bad filter. Well i will be watching the thread and am anxious to find the issue. luckily a 2005 with 6K on it should be under warrantee. WOO HOO!!!
Old Jun 25, 2007 | 08:41 PM
arctic y block
Never owed a rig with a warranty. Didn't think of that. What a concept
Old Jun 25, 2007 | 08:47 PM
puddle jumper's Avatar
puddle jumper
Im still betting the fuel pump.Ive seen too many pumps fail.Even a tea spoon of water in the tank will take them out.Make shure the shop drains the tank compleatly to get all of the gunk out of it.Also have them check the tank vent tubes for holes in them or you will be back to the same thing all over.
Old Jun 25, 2007 | 09:03 PM
poppie's Avatar
poppie
next time you park that rig 1st fill the tank "FULL" and add conditioner to it,tank's that are part empty SWEAT inside.
Old Jun 25, 2007 | 09:20 PM
puddle jumper
Very true motor houses that sit alot can get water in a half full tank from the tank sweating.
Old Jun 26, 2007 | 05:27 AM
  #28
TD3619's Avatar
TD3619
Thanks guys for the input. Unfortunately they told us yesterday that the onyl thing that would be covered under warranty was the tow to the facility! Unbelievable if you ask me.
Old Jun 26, 2007 | 07:45 AM
  #29
arctic y block
That just don't seem right to me.
Old Jun 26, 2007 | 11:14 AM
  #30
krewat's Avatar
krewat
FTE Leadership Emeritus
Did they ever actually fix it yet?
