how much paint for motorcycle???
Just the paint.
One pint or a full quart total???
Just the saddle bags.
How much paint would it take to paint JUST the fiberglass saddle bags?
If you're using a 2-stage, opposed to 1-stage, paint then you'll be a lot better off. If you don't already know, that's what the pro's use. Two-stage paint allows you to wetsand the color coat until it's virtually flawless, then you apply the clear-coat; which also allows you to wetsand and spray your second coat over, before buffing to a mirror finish.
The two-stage method will allow your paint to be color-matched very closely to your frame/tank, unlike the one-stage method, which has the clear and color mixed. Your local paint mixer's skills will depend upon how close either paint will match the desired color, but a majority of mixers will agree that two-stage paint is the better of the two choices.
The problem with one-stage paint is that any imperfections are going to really stand out, that piece of lint that landed in the paint on the first application is going to be compounded three-fold by the time the last coat of is applied. As it would with a two-stage paint, but you can get rid of those imperfections a lot earlier because you have the ability to wetsand each coat.
For two fiberglass saddlebags I would say that a pint of paint is more than enough for a one-time application, because in most cases you can easily thin it by 50%, giving you the ability to apply at least two coats of color per "bag."
KEEP IN MIND however, that it's always safe to have more paint than you need, for future touch-ups or other projects, so you might want to get a full quart? With a two-stage paint the touch-ups are a lot easier to perform than a one-stage paint is!
I've tried both and favor the color/clear method.
I would get a quart because the pint of paint you have color-matched today might not look the same as a pint you have color-matched a year from now. Then, you get one pint of clear (or a quart) and a pint of hardener (only seen sold in pints but you use very little of it with the clear), and voila, you're done--unless you have to buff out some "orange-peel?"
You don't need a fancy paint gun either, a $20 gravity fed touch-up gun from Harbor Freight is all you really want for small project projects, make sure you have an inline water filter too! That $2.50 will save you from splattering a drop or two of condensed moisture from your air compressor/hose onto your paint!
Other than that, I'd guess you'd spend around $50-$60 for all of your painting supplies, up to a $100 if you have to buy a paint-gun...borrow an air compressor if you don't have one already.
v/r,
Phil
1) base coat
2) top coat
3) clear coat
(acrylic urethane)
Is this what you call a two stage?
So, I could apply the base coat, let it dry, wet sand then apply the top coat, let it dry, sand and then the clear coat??
thanks,
1) base coat
2) top coat
3) clear coat
(acrylic urethane)
thanks,
1) Sand the fiberglass saddle bags with 600-something grit wetpaper under a rubber sanding block, wipe with clean hand while rinsing with clean water, and allow it to completely dry after blowing the excess water away with compressed air.
2) Wipe the surface with a tack cloth.
3) Spray on the first coat of primer, and allow it to completely dry.
4) Wipe surface with a tack cloth.
5) Spray on a second coat of primer, and allow it to completely dry.
6) Lightly sand with 800-something grit wetpaper under a rubber sanding block, wipe with clean hand while rinsing with clean water, and allow it to completely dry after blowing excess water away with compressed air.
7) Wipe the surface with a tack cloth.
8) Spray on the first coat of color, and allow it to completely dry.
9) Lightly sand with 1000-something grit wetpaper under a rubber sanding block, wipe with clean hand while rinsing with clean water, and allow it to completely dry after blowing the excess water away with compressed air.
10) Wipe the surface with a tack cloth.
11) Spray on the second coat of color, and allow it to completely dry.
12) Lightly sand with 1400-something grit wetpaper under a rubber sanding block, wipe with clean hand while rinsing with clean water, and allow it to completely dry after blowing the excess water away with compressed air.
13) Wipe the surface with a tack cloth.
14) Spray on the first coat of clear, and allow it to completely dry.
15) Lightly sand with 2000-something grit wetpaper under a rubber sanding block, wipe with clean hand while rinsing with clean water, and allow it to completely dry after blowing the excess water away with compressed air.
16) Wipe the surface with a tack cloth.
17) Spray on the second coat of clear, and allow it to completely dry.
18) If satisfied, you're done with the painting.
19) If you're not satisfied, something fell in the clear, repeat steps 15-17 until you're satisfied. You don't want too many coats of clear, five is more than enough.
20) Only if desired....finish by polishing with a high-speed wheel.
The primer is more of a "given" than part of the color/clear application because it isn't always necessary if you're painting over something that is a neutral color.
For example, if your saddle bags were purchased without a factory paint job, or they were painted with a completely contrasting color, then you would want to use primer. If the saddle bags did come with a factory paint job that is similar to the new color you want to make them, then you don't need primer. You just have to lightly sand them to give the new paint something to bond to, and clean with a tack-cloth. Make sense?
v/r,
Phil
My base coat is actually a color.....white.
Then the second coat is another white and
then the clear coat.
It's called pearl white for the road king.
The process is the same with the metallics, as I outlined, except you insert the second white before the clear.
1) Primer (optional if painting over a new factory finish, prep the same though)
2) First White coat
3) Second (pearl) White
4) Clear
If you have never painted pearls before, I'd recommend you practice on something small, 8x11-inch sheet of fiberglass/sheetmetal---Just a thought?
v/r,
Phil
bases..... for PPG/Omni 1:1 mix
DBC - flash time 5 - 10 mins
DBU - flash time 10 - 15 mins
MBC (Economical priced) flash time 5 - 10 mins
Enamels... PPG/Omni
MAE (Economically priced) 4:1 flash time 5 - 10 mins
Acrylic urethane.....PPG/Omni
MTK (Economically priced) 4:1:1 - High solids = 4:1/2:1
DCC 4:2:1 or 4:1:2 or 2:1:2 (depends on activator used) flash time 5 - 10 or 10 -15 mins
Clears....PPG/Omni
DCU 2082 Strato-clear 2:1 flash time 2 - 5 mins
DCU 2042 low VOC speed clear4:1:1 flash time 5 - 10 mins
MC161 High solds Urethane 2:1 flash time 5 - 10 mins
Sherwin williams....
bases.....
Ultra 7000 1:1 flash time 2 - 10 mins depending on reducer
Urethane Enamel....
3rd demension 8:4:1 flash time 30 mins @ 140 degrees or 12 hours or so air dry
Acrylic enamel....
VOC acrylic 8:4:1 flash time 30 mins @ 140 degrees or 12 hours or so air dry
Primers are to fill scratches mostly so if ya have scratches spray primer a few times but sand in between the coats even on the last primer coat b4 the color coats begin. When you spray PEARLS make sure the spray pattern in the gun is where you want it first. When I spray pearls i tend to hold the gun a little farther back than when painting solid colors. As for painting with the gun go a panel at a time with 50/50 overlap. When clearing it after you color, spray a "dry" coat first then spray a wet one then wait for the flash time throw another coat on it. Dont have to wet sand between primer coats (regular sand paper) but wet sand between color coats & also clear coats. good luck
Enamels... PPG/Omni
Clears....PPG/Omni
bases.....
Urethane Enamel....
Acrylic enamel....
He's right about the sandpaper not having to be a "wet-grade" when sanding the primer, but I usually have more of it in my garage, so it use it for everything.
As for the flash time, and spraying more color, I think that's more of a time saver and a personal preference. In the past I've color coated, allowed it to flash, then sprayed on a second to make sure there's an absolute even coat of color, then wetsand after it has dried. Then I became more comfortable with my gun and spraying technique. By the time I applied my 3rd coat of color it is perfect, then the clear coats begin.
It really comes down to technique and time I suppose?
Always follow the paint manufacturers directions for mixing paint, I simply gave a generic guideline in my previous post!
Results were fine....not great but I'm satisfied. Small run in the clear coat but could wet sand that out if I wanted.
Oh yea, 16 oz's of paint at each stage is too much paint. Could how gotten by with maybe 8 oz's, which becomes more since I had to add the activator and the reducer.
Anyway, the pearl sprayed on good. I could use some pratice though. Saved money doing it myself and was able to buy a new gun.
FX-100, by sharpe.
Again, the paint I used was "AU"
'base coat (white)
'pearl coat (whiteish, blueish, greenish) Hence "pearl"
'clear coat
