how much paint for motorcycle???
Use 1 Quart of Paint for a Harley Davidson RoadKing!
Try a search for motorcycle paint, you will find: Motorcycle Paint Supply - They have OEM formulas for just about any age motorcycle. They have 2 ounce touch up bottles with a brush in the cap. Also, they can supply pints, quarts, and complete repair and refinishing kits.
They also tell how much you need for each project, with a lot of technical information. Brand new Motorcycles, to Vintage.
Same with new or vintage Ford Truck colors! see www CycleColor com
* 1 Quart of Base-coat and 1 Quart of Clear-coat with a Pint of activator for the clear should do the job. If it is a
Tri-coat color you could use up to a quart each, depending on the transparency of the mid-coat color.
Jackpiner
Jackpiner
Finished!Results were fine....not great but I'm satisfied. Small run in the clear coat but could wet sand that out if I wanted.Oh yea, 16 oz's of paint at each stage is too much paint. Could how gotten by with maybe 8 oz's, which becomes more since I had to add the activator and the reducer.Anyway, the pearl sprayed on good. I could use some pratice though. Saved money doing it myself and was able to buy a new gun.FX-100, by sharpe.Again, the paint I used was "AU" 'base coat (white)'pearl coat (whiteish, blueish, greenish) Hence "pearl"'clear coat
...*Small run*...... in the clear coat but could wet sand that out if I wanted.
...It really comes down to technique and time I suppose?
