General Diesel Discussion
engine info/history assitance
Old Jun 23, 2007 | 01:55 PM
IDIPower's Avatar
IDIPower
hello all,
first of i'd like to say greetings, and hopefully this will be the first of many beneficial posts for everyone.
I am currently working on a brief history of the domestic manufacturers
diesel light duty-heavy duty pickups 1978-current models, 1/2-1.75 ton(f550/gm 5500/dodge 5500), including, chassis,diffs,tcases,trannies,cabs and spec packages. i have found very little info
regarding these on the net and the books and other publications that I have are limited in regards to these specs.
what i am currently searching for however, is information pertaining to the in-direct injected diesels from 1978-1992 5.7 gm/6.2 gm and naturally aspirated 6.5 gm( i have enough info on the 6.5turbo) as well as the 6.9/7.3na and 7.3 turbo navistar/ford engines and transmissions behind these engines as well as the differentials and transfer cases.
thank you very much. more to come...............
Old Jun 23, 2007 | 01:59 PM
pfogle's Avatar
pfogle
In the fords you had three transmission options, from the beginning you had a 5speed manual (forget what make the early ones were), or a C6 Ford automatic. After 1989 you had three choices, a ZF 5 speed, a C6 3 speed auto or an all new E4OD Ford automatic overdrive. Rear ends were either a ford 10.25" or a Dana 60 (F250/350 SRW), or a dana 70 (F350 DRW). Ratios were 3.55, 3.73, or 4.10.
640 CI Aluminum FORD
Ford vs The Competition
Dec 21, 2012 10:20 PM
lio45
Oct 3, 2012 08:46 AM
Truck451
General Automotive Discussion
Dec 29, 2009 08:13 PM
biz4two
Jul 7, 2004 10:08 PM
weldman
Feb 14, 2001 11:31 AM
