explorer heads?
Old Jun 27, 2007 | 08:21 AM
lostin90s's Avatar
lostin90s
on the topic of gt40 heads .
Aside frome problem with exhaust manifolds. Are these heads intake spacific? Or is the intake valley the same? I have Maf on my 94 F150 now . What would have to be changed if want to use the intake? I have read of flipping the top portion ETC. But are the TB wiring set up about the same?
The reason is I have access to 2 96 explores . And a short block waiting to havethe head put on it.
Old Jun 27, 2007 | 07:43 PM
TigerDan's Avatar
TigerDan
Intake side of the P heads is the same, no differences there. But if you have '96 Explorers, they'll have the regular GT40 heads, not the P heads.
You're talking about using the Explorer intake on your F150? The intake runners are shorter and you'd probably lose some bottom end. I believe the throttle bodies on all the aforementioned intakes point to the passenger side. You're probably thinking of the earlier non-H.O. vs. H.O. passenger car intakes, where the non-H.O. had the TB on the driver's side...
Old Jun 27, 2007 | 07:58 PM
RacinNdrummin's Avatar
RacinNdrummin
The intakes can be put on facing either way.
dawgs4x4
Mar 27, 2013 07:15 PM
kadrocker
17
Apr 11, 2009 02:15 PM
Redneck1465
19
Jul 30, 2008 12:37 PM
desperado
Sep 22, 2001 09:41 AM
78bigblock
Apr 4, 2001 12:43 PM
