Am I correct in that the superchip changes the firing timing to utilise premium fuel?
I think these efi engines are set up to run as lean as possible. Are there chips out there that make the engine run more rich but still on regular gas? Maybe they trick the computer into thinking its a cold start or something?
Sound System: Stock Stereo, RockfordFosgate 800 watt amp, Vega 18" sub (400 watt rms), one Cerwin-Vega LS-12 3 way floor speaker with the Vega sub removed (because I blew it) and a RockfordFosgate 12" sub (500 watt rms) in its place. And one Boise floor speaker with a 75 watt power capacity (you know it ain’t gonna last).
Performance Mods: K&N Air Filter.
Cosmetic Mods: Black Grill Guard, 5% window tint, bug guard, bed liner.
Daywalker: The only manufacturer that I know of that attempts to trick the ecu into thinking that the engine is running cold is Hypertech. This is why they suggest that you purchase their cooler thermostat with their product. Diablo and Superchip both change the timing curve and advance the timing quite a bit for premium fuel. This is why you get a pinging problem with regular fuel, the timing.
Thanks
Danny
2001 Escape=Wifes' Ride
2001 Cobra=My Rod
DiabloSport Chipped
342 HP=Quick
Danny
You don't need an expensive chip to make the computer think it's colder, a few $.25 resistors from radio shack will do the same thing. Check it out here: http://rogueperformance.com/IntakeAir.html while you're there check out some other stuff too, some looks pretty interesting.
Dave: Read the above,,,Superchip and Diablo DO NOT try to trick the ecu into thinking the car is running cold. That would be an inefficient way to try to gain horsepower. When cold, the ecu raises the duty rate on the injectors, thereby adding fuel. It does not, however, adjust the timing proportionately. The 2 above mentioned chips alter the timing curve, changes the air/fuel ratio, and advances the entire timing curve, raises the rev limiter, raises the speed limiter, raises the fluid pressure in the autos. That is a bit more than a couple of resisters can do.
Danny
2001 Cobra-Lazer Red
DiabloSport Chipped
340 HP
Danny
