coolant filter
Old Jun 22, 2007 | 01:17 AM
faststang94's Avatar
faststang94
coolant filter
due to problems with cavitation on the 7.3s i was thinking maybe it would benefit if i rigged up some sort of coolant filter like the big trucks have. keep the coolant nice and clean letting all that additives work as they should. has anyone ever done this ?
Old Jun 22, 2007 | 06:53 AM
CRMW's Avatar
CRMW
I have one, here is a link to a tech article on Oilburners on how to instal one.
Coolant Filter
Chris
Old Jun 22, 2007 | 07:46 AM
kf4hoq's Avatar
kf4hoq
I'd have to install 3 of them on my radiator!! Even after adding 2 gallons of coolant right after I bought the truck a year ago, it still looks like mud water is running through the radiator! I've thought about doing a flush, but I'm scared that a rust plug will break loose and then the radiator would leak!! That would be just my luck!
Old Jun 22, 2007 | 09:21 AM
Learath's Avatar
Learath
my truck came with rusty muddy water. took about 8 changes before it was clean enough for me to bother putting some proper coolant in it. much cleaner now but a filter would not be a bad idea.
Old Jun 22, 2007 | 11:22 AM
1989 Ferd's Avatar
1989 Ferd
I installed one on my sons truck in the same place as the one in Oilburners. However I did not buy all the plumbing he used. I purchsed the filter kit, 2 -5/8" tees and necessary hoseclamps at Napa. I also purchased one ball valve and 2 brass rubberhose adapters at a hardware store. It was an easy installation and I can close one side to remove the filter though there will be some loss from the return side.
hi-jacker
Oct 27, 2014 02:26 PM
barnhartred
Jan 17, 2014 01:41 PM
Headviking
May 17, 2012 10:42 AM
amd_038
Aug 20, 2011 08:03 PM
Headviking
May 21, 2010 06:05 PM
