Smart computer???
Old Jun 21, 2007 | 09:32 PM
pepito113's Avatar
pepito113
Question Smart computer???
I was told by a friend that if you put in a cai and change the exhaust the computer will notice that the truck is going lean and will change the computer program, therefore making your upgrades pointless? I guess what he is saying is that the computer will adjust the program. And you are back to stock. And ideas?
Old Jun 21, 2007 | 09:35 PM
ford390gashog's Avatar
ford390gashog
How would those two mods make the engine run lean?
Old Jun 21, 2007 | 09:38 PM
pepito113's Avatar
pepito113
I am not sure. I guess he said that the computer would notice the changes and adjust. I am not sure. Just wondering if there was some truth behind that?
Old Jun 21, 2007 | 10:15 PM
screwy's Avatar
screwy
The computer will adjust itself to keep the engine running at the correct Fuel / Air ratio, but a CAI and exhaust do not modify this ratio, they just help the engine breath better. So No, the computer will not adjust itself to negate the modifications.
Old Jun 22, 2007 | 09:34 AM
pepito113's Avatar
pepito113
ok. Glad to hear it was all for nothing
Old Jun 23, 2007 | 04:39 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
friend = idiot
the PCM will adjust the fuel to maintain the factory A/F ratio and keep the motor in safe parameters.
you will see improvement with a CAI and exhaust. But to maximize the gains, you need to get an Edge/Diablo or get some custom Dyno tuning done.
Old Jun 24, 2007 | 03:40 PM
Tom's Avatar
Tom
Tylus is right here, as usual.
Think about it...in order for your engine to run lean, it has to be getting too much air and too little fuel. Obviously a CAI and exhaust ain't gonna screw with the amount of fuel, but it will cause better airflow. This is going to give you more air.
The PCM will correct for it, adding fuel to correct the mixture.
What does more air and more fuel equal? MORE POWER.
tex25025
Mar 16, 2009 08:16 AM
Garycas
2004 - 2008 F150
Feb 28, 2005 08:48 AM
Silverrv
Oct 12, 2003 07:20 AM
vbdotnetdev
Computer Chips & Tuners
Oct 6, 2003 07:07 PM
Knight Prowler
Sep 23, 2003 06:18 PM
