Sponsored by: Auxito
Another a/c question
Old Jun 21, 2007 | 07:10 PM
jared66's Avatar
jared66
I have a 98 4.6, automatic, 4x4, extended cab with 60,000 miles. The a/c is not blowing cold air. I noticed that the a/c clutch cycles on and off. Is this normal, and if so how long should it stay on and off when the a/c is on?
Thanks
Old Jun 21, 2007 | 07:13 PM
LxMan1's Avatar
LxMan1
It should stay on for quite a while. If it is short cycling, then it is probably low on freon. If it is cycling every 5 to 10 seconds, then it is low.
Old Jun 21, 2007 | 07:14 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
myne takes forever to get cold...and its not even that good... takes 25 min at full to run you out
jared66's Avatar
jared66
thanks for the info
Old Jun 21, 2007 | 07:17 PM
jared66's Avatar
jared66
Im guessing that its not a fuse or a relay if its short cycling.
Old Jun 21, 2007 | 08:26 PM
steve(ill)'s Avatar
steve(ill)
if it cycles then you are o.k. electrical--------- with the proper amount of R134 inside, it will not cycle, or will be quite a while between cycling. if you have a gauge set, you should have about 35 psi on the low side and 300 psi on the high side (estimates). you will cycle if the freon runs really low ( like 15 psi) or if it is way overfull and the pressure goes up to 400 psi.
Old Jun 21, 2007 | 08:35 PM
jared66's Avatar
jared66
On the low side i have 35 when the compressor is not on and 55 when it is on. do I need to let some out and if so how?
Old Jun 21, 2007 | 09:10 PM
jared66's Avatar
jared66
that was backwards. its 35 when the clutch kicks in and 55 when its off
Old Jun 21, 2007 | 10:17 PM
steve(ill)'s Avatar
steve(ill)
motor off, you should have 100 psi. motor running , AC on, it will pull down to 35 psi as it pushes the freon to the opposite side. if it pulls much lower it will kick out. if you have 35 psi and it is kicking out, you may want to check the high side pressure, maybe it is kicking out on "high". there is an orifice tube between the high and low side. if the low is o.k., and the high is too high, then you dont have too much freon, you have a partly plugged orifice tube.
Old Jun 21, 2007 | 10:48 PM
jared66's Avatar
jared66
Is there a good way of fixing the plug?
Old Jun 22, 2007 | 10:00 AM
projectSHO89's Avatar
projectSHO89
If you're reading 35/55 psi at the cycling limits, you probably need a new gauge (perhaps a cycling switch).
Correct cycling values are 22.5/45 psi.
It is very unlikely that you are kicking out due to the HIGH side pressure switch. You'd have to have the low side almost into vacuum for that to happen unless you were over charged, an improbably event except where a DIYer has been screwing with the charge level.
In any event, you are likely undercharged due to a leak in the pressurized system.
Steve
Old Jun 23, 2007 | 08:48 AM
steve(ill)'s Avatar
steve(ill)
you really need to check the HP side to get a final answer to your problem. if the orifice is partly plugged then you will get way too much psi on the high side since it cant exapnd thru the hole and get back to the LP side. this is not an easy job, the freon would ned to be extracted, hose disassembled and tube removed, new installed, pull valcuum, then add the refrigerant back to ploler level.-----project is right, the dont happen by itself. since you have a 98, i can assume the guy befor you might have added a can of gas once or twice. he couldl add to much, or got contaominants during the fill that plugged the orifice.---------- only knowing the pressure will tell you.
