leaking fuel hard starts
Old Jun 21, 2007 | 12:05 PM
dude73's Avatar
dude73
Question leaking fuel hard starts
i have a 88 f250 7.3 idi 5sd 4x4 when cold it starts ok when hot it dosnt like to start at all and it started leaking fuel from the front tank so i started using the back tank the front tank stoped leaking about 4 weeks later the back tank started to leakfrom the top of the tank whats making it do this how can i fix it
Old Jun 21, 2007 | 08:00 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Sounds like you have 2 issues. First when it is cold and starts Ok but when hot no start. This is an indication of the injection pump starting to go bad. Second issue: Probably around the fuel sensor or fill pipe you have got a small hole which has started to leak. About the only fix I know is to pull the tank and see what is going on first before doing anything else.
mike L
39
Nov 23, 2014 09:33 AM
merbno
Oct 14, 2014 05:36 PM
regidog
May 1, 2013 07:58 AM
MyBallsHurt
Feb 15, 2013 06:05 AM
altruego
May 17, 2011 04:04 PM
