How much fuel do PSD injectors flow???
Old Jun 21, 2007 | 05:18 PM
dc2842002's Avatar
dc2842002
That good to know. still think that 120cc must be a flow rate not just a volume of flow. 120cc is a lot to flow that quick. Even if you triple the numbers I've seen for injector pulse width that is still less than a hundreth of a second.
Old Jun 21, 2007 | 05:29 PM
dsldrvr's Avatar
dsldrvr
Yes, we seem to agree, unless they just messed up on the units, it pretty much has to be a flow rate.
Old Jun 21, 2007 | 09:39 PM
ernesteugene's Avatar
ernesteugene
My New (hopefully correct) Version!
I'm playing Wikipedia and posting the following as being the correct version! If anyone comes across any data that contradicts this version, please play Wikipedia with me, and let me know of any needed corrections.
IMSV=Injector Maximum Stroke Volume, mm3
AA....90 mm3 single shot
AB...120 mm3 Split shot (Early 99)
AD...140 mm3 Split shot
AC...160 mm3 Single shot
Stage-1's...basically same as AC's
Stage-2's...180 mm3 single shots
stage-3's....215-250 mm3 single shot hybrids
BD...250 mm3 single shot
I'm using this version of the data in my new model to calculate the IMVFF=Injector Maximum Volume Fuel Flow, gal/hr=gph, as IMVFF= (4)(60)(2.642x10^-7)(IMSV)(RPM)=(0.00006341)(IMSV)(RPM) in GPH, where 4 is because of 4 strokes per rev, 60 converts from min to hr, and 1mm3=2.642x10^-7 gal. I then use IMVFF to normalize the actual calculated VFF in my model as (VFF/IMVFF)%, to make sure that the injectors aren't limiting the VFF in my RWHP calculation.
Old Jun 21, 2007 | 10:41 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I only read your first (original) post Gene, not the rest of the thread.. It is 120cc of fuel for every 1000 injection events. Hmm, or is it 100?
Old Jun 21, 2007 | 10:48 PM
monsterbaby's Avatar
monsterbaby
just thought of another way to look at this adn show that 120cc has to be max flow rate, look at a motor cycle engine you know like say a 125 cc dirt bike, now try to figure out how to put 8 of those under your valve covers
Old Jun 21, 2007 | 10:53 PM
PowerstrokeJunkie
It must be 1000 events then.
Old Jun 22, 2007 | 01:11 AM
TNT in Round Rock's Avatar
TNT in Round Rock
Kris do you have the data and formulas to back that up ?????
Old Jun 22, 2007 | 09:24 AM
monsterbaby
I am thinking they are rated like a carb would be, or the older gas injectors were rated at lbs/hr more than likely. I am guessing (just a guess have no proof but it would make sense) they are rated at CC per minute kind of like a carb is rated CFM (cubic feet per minute)
Old Jun 22, 2007 | 09:30 AM
rbaker6336's Avatar
rbaker6336
back in days of old the injectors in a detroit diesel were rated at CC per minute
Old Jun 22, 2007 | 09:35 AM
rbaker6336's Avatar
rbaker6336
never did try to stop and figure it out but 4 70 cc injectors at 2200 rpm would flow about 5 gal an hr
Old Mar 1, 2021 | 07:43 PM
Will3406C's Avatar
Will3406C
Sorry just noticed this is really old
Last edited by Will3406C; Mar 1, 2021 at 07:45 PM. Reason: Sorry just noticed this is really old
hddave44
Apr 8, 2015 03:37 PM
Blind Driver
Jan 7, 2013 10:46 PM
jimwilsonmasonry
Jan 7, 2009 09:19 PM
TN97STROKE
Apr 29, 2008 04:46 PM
parkland
Apr 19, 2006 12:13 PM
