inj flow?
Old Jan 7, 2009 | 08:18 PM
jimwilsonmasonry's Avatar
jimwilsonmasonry
inj flow?
since our injectors bench flow 95 cc of fuel maxed out and we only use a fraction of that amount of fuel through our engines why do we have to upgrade the tips and nozzles of our injectors to push more fuel when they can already pump tons of fuel on a bench test
Old Jan 7, 2009 | 08:38 PM
tjbeggs's Avatar
tjbeggs
The CC rating is over 1000 cycles of an Unknown "open" time. Could be 2ms (resonable) or 4 ms (not so reasonable).
I just got a good lesson in injector ratings. There is no set standard for reporting injectors sizes...
So with that said we still have baby injectors and need bigger injectors for more power.
Old Jan 7, 2009 | 09:19 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
What do you mean "...We only use a fraction of that through our engines..."???
At 3k rpm, and as much fuel as a custom chip calls for, you're getting pretty much every last drop available.
And you only need to stroke the Piston more to get more fuel without adding larger nozzles. I know someone who saw 430 hp on stock nozzles. Actually I think there are a few guys...
Upgrading to larger nozzles will get the fuel out in a quicker time, thus more power. Larger nozzles do not change the displacment of an injector, just the time it takes to empty it.
And the stock AA injectors hardly pump "tons of fuel." Adding an entry level injector like a Stage-1 with good programming will add about 100 hp on a truck with just a chip. And that's on stock nozzles, too...
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
hotrodfeguy
Feb 13, 2017 09:20 PM
delewskifamily
Apr 10, 2015 09:23 PM
Tim Hodgson
65
Nov 30, 2012 01:22 PM
jborushko
Feb 14, 2012 11:45 PM
rotun
29
Nov 27, 2009 12:40 PM
