Sponsored by: Real Truck
Day time running lights
Old Jun 21, 2007 | 06:06 AM
fishfiles's Avatar
fishfiles
How do you turn off the day time running head lights on a 2006 Ford 350
Old Jun 21, 2007 | 07:46 AM
CrazyKen's Avatar
CrazyKen
Your light switch has 4 positions, if i'm not mistaking... all the way turned to left, is daylight running lights, move one position to the right is off position, one more to right is parking lights, then last to right is headlights, pull switch out for fog lights.
Hope this is info your needing, if it's an electrical thing in the wiring, then I am not the person to answer your question.
Cheers Ken W
2005 F350 DRW King Ranch CC long bed Oxford white / Arizona beige. 4:10. Auto
Old Jun 21, 2007 | 07:56 AM
Lonewolftx's Avatar
Lonewolftx
Question
Well on my '06 all the way to the left is auto light mode which allows them to turn on and off based on the ambient light available. There are no running lights at all.
Old Jun 21, 2007 | 08:00 AM
CrazyKen's Avatar
CrazyKen
Unhappy
Your right, what was I thinking of ? You can tell i've been up all night.
Old Jun 21, 2007 | 09:34 AM
msgtg's Avatar
msgtg
My 03 has the same feature so I'm sure your's should be the same.
Old Jun 21, 2007 | 11:54 AM
GregsSD's Avatar
GregsSD
I believe the Canadian trucks come with the daytime running lights and the U.S. trucks don't.
You might try looking to see if there is a dedicated fuse for DRL (daytime running lights) and take it out. That is all I did on my GMC truck that had them but my f-250 doesn't have them so I am not 100% sure.
Old Jun 21, 2007 | 01:36 PM
wiingnut's Avatar
wiingnut
Look and see if it was an aftermarket module. If so, then pull inline fuse. If it was a factory setup (fleet or Canadian) then there may be instructions in manual. If not, try dedicated fuse in your fuse panel
Old Jun 21, 2007 | 02:32 PM
pilotshot's Avatar
pilotshot
All Canadian vechicles must have daytime running lights by law. If you have key on to any position of power the running lights will come on. When you select light switch ON for night driving the daytime running lights go out. The rear tail lights do not come on when running lights are on. The daytime running headlights operate at a lower candle power that regular headlights in the ON position.
When a used US owned vechicle is sold into Canada, Border Customs require running lights. Many shops are set up to do the simple conversion.
I strongly support the running lights. I noticed in US safety corriders that headlights are recommended. Why not have running lights during the day with no tail lights so braking can be seen better during the day when brakes applies. The running lights in Canada has reduced the head on collisions when passing vechicles in daylight.
Old Jun 21, 2007 | 04:51 PM
fishfiles's Avatar
fishfiles
Day Lights
My truck is a 2006 350 superduty , I think the truck would be consider fleet as it was orignally cab and chassis , wheather it's Canadian built or not I am not sure , the light switch on it is a old style pull out , there is no extra click for a auto mode , the running lights don't come on with the day time running lights which is the first problem why I don't like them is that so many times I am driving home and as it gets dark the headlights are already on and you don't realize that the tail lights are not until it gets dark enough for you to see the dash board is not lite up , the second is a let my truck run atlot while parked , it gets very hot here in New Orleans and I let the A/C run while I am out the truck , the lights stay on and I am tired out of people telling me my lights are on
Old Jun 21, 2007 | 05:28 PM
bpounds's Avatar
bpounds
The U.S. did that a long time ago for motorcycles. Some studies have shown that while it works for a while, the human brain gets used to it and the benefit diminishes. Here in CA we have sections of the most dangerous highways where DRL is required/recommended (not sure the signs have the force of law). Maybe it works on those sections because it is special.
It does seem to still help with MC's and it would worry me that if all vehicles were required to have DRL that any benefit for bikes would be lessened. And our scooter buddies need all the help they can get.
Just my $.02
Old Jun 21, 2007 | 05:44 PM
bandlgeorge's Avatar
bandlgeorge
I have a 2002 CC LB 4x4 PSD that has the 4 position switch. Auto-Off-Parking lights-Headlights. (pull-out for fog lights) I to did not like the DRL's and pulled the appropriate fuse in the panel below the steering column. In my truck it is fuse #14, a 15 amp blue fuse. See pics in my gallery for illustration. Sorry-Couldn't figure out how to add picks to the message
Old Aug 10, 2007 | 10:01 AM
MLCRI$I$ II's Avatar
MLCRI$I$ II
Was your truck built in Canada? How is it that you have DRLs on an 02? I have autolamp on my 06, but no DRLs. Maybe I missed something . MLC2
Old Aug 10, 2007 | 11:33 AM
bandlgeorge
It's a canadian. Came into Canada, had to have the instrument cluster swapped when the original buyer changed his mind and it was shipped to the US. I do like the autolamp feature, but not the DRL's.
Old Aug 10, 2007 | 11:38 AM
Majic31's Avatar
Majic31
Turn off DRL's while PARKED
I am in Canada and have DRL's as required. When parked, and when I don't want the DRL's on while doing so, I simply apply the emergency brake, and the DRL's turn off..
Old Aug 31, 2007 | 01:42 PM
jdevlin's Avatar
jdevlin
Found this info on another site.
The DRL connector has 8 pins for the following:
# 1 - High beam indicator lamp
#2 - Fused run only feed
#3 - Brake warning indicator lamp
#4 - Fused, hot at all times
#5 - not used
#6 - Parking brake on input
#7 - Low beam output
#8 - Pulsed voltage to high beams
The jumper used when a DRL is not plugged-in jumps pins 1 & 8
together, and 3 & 6 together.
Also with the proper plug-in DRL module and correct wiring harness
there is no "headlight wiring to put back the way it was" just
unplugged the module and plug the jumper cap back in.
Stangfire
1997 - 2003 F150
Feb 4, 2014 03:53 PM
mike2366
Dec 31, 2013 01:44 PM
wicat3
Aug 13, 2012 11:14 PM
Dave XLT
6.7L Power Stroke Diesel
Jan 7, 2011 09:47 PM
01 EXCURSION MORRIS
Jul 13, 2010 11:43 AM
