Convertor recommendations
Old Jun 20, 2007 | 10:43 PM
staysbroken's Avatar
staysbroken
Also posted in the '73-'79 forum...
Truck is a '78 2wd C6 3.50 rear...
Engine will be:
'78 460 ~8.5:1
Mildly ported D3 heads
Edelbrock Performer
Holley 750
Comp XE262H
Headers w/ 2 1/4 duals
I'm expecting torque peak somewhere around 2800 rpm and hp at or just below 5000.
Basically, this will be an all-purpose daily driver... I want to be able to tow 6-7000 pounds reliably, potentially long distances. I'd also like to be able to take it to the drag strip once in a while and have some fun (hopefully somewhere in the mid-14 second range?)
Just looking at Summit's selection, I like the TCI Sizzler 1700 rpm convertor, and the TCI "High Torque Towing" 1200 rpm convertor. I think something in the 1700 rpm range would be ideal, but at the same time I'm worried that a "street/strip" convertor wouldn't last too long towing any kind of significant load. Do you guys think a convertor rated at 1200 is too tight for that cam? For comparison, what does a stock convertor stall at?
Thanks guys
Old Jun 20, 2007 | 11:20 PM
Torque1st's Avatar
Torque1st
Posting Legend
Sounds like you need two different vehicles. That engine setup with a towing converter would probably work great for towing. To run on the strip you need another setup.
Old Jun 21, 2007 | 08:18 AM
staysbroken
Hmm... that's what I was afraid of. I guess an OEM reman convertor would be a decent compromise?
Old Jun 21, 2007 | 11:06 AM
75F350's Avatar
75F350
The XE series cam from Comps is actually recommended for use with stock style converters. If you are going to tow, you will want the stall speed to be pretty low. If you get too high, the converter will slip while towing (3.50 gears and unknown tire diameter, so this is speculation) assuming a tire approx. 32 inches.(taller tires would only make matters worse) This will generate a considerable amount of heat, and you will struggle with a hot transmission while towing.
That thing is going to make a bunch of torque, so go with it, don't try to raise rpm's for a better 60 foot time. It will probably just spin the tires anyway, and trying to make additional horsepower during acceleration will only make matters worse.
Old Jun 23, 2007 | 09:17 AM
fasthauler's Avatar
fasthauler
The stock converter spec's are; stall ratio - 2.03, stall speed 1760-2140 RPM's. That is if my manual is correct. They claim the stall speed will be a little lower at high altitude.
Roger Davis
Nov 23, 2007 03:21 PM
The67Beast
Offroad & 4x4
18
Nov 8, 2007 08:31 AM
sasquatch999
Oil & Lubrication
Oct 23, 2007 08:37 AM
Sporer65
Offroad & 4x4
Aug 10, 2007 01:56 PM
macwilj
Jul 28, 2007 08:26 PM
