Fss
Old Jun 20, 2007 | 10:34 PM
DNewton's Avatar
DNewton
Fss
is it possible for the FSS to go out? i fixed my fuel tank problem(i think) and now it just cranks and cranks and wont fire even with a shot of starter fluid, and not exhaust is coming out.....
Old Jun 20, 2007 | 10:54 PM
faststang94's Avatar
faststang94
never use starting fluid in a diesel, unless you want a bent rod
Old Jun 20, 2007 | 10:55 PM
DNewton's Avatar
DNewton
yes i know thank you, but what im saying is, that it wont even start with that!
Old Jun 20, 2007 | 11:00 PM
faststang94
weird. have you checked to see if your glow plugs are cycling?
Old Jun 20, 2007 | 11:05 PM
DNewton's Avatar
DNewton
they are on a switch, which the previous owner said didnt work, let alone it has all bad gps, which is fine with me, but another thing that gets me is i had it running and probaly drove it 200 miles before it stopped running...
Old Jun 20, 2007 | 11:17 PM
faststang94
did it die when you were driving it? if it started then doesnt mean it will start again. id get new glow plugs and see what happens since it sounds like you need them anyways
Old Jun 20, 2007 | 11:32 PM
DNewton's Avatar
DNewton
i agree, and yes, it died while driving, had to get my buddy to tow me home with his chevy(my head is still hanging) the problem is, im not getting fuel....i have clear line at the tank ware i just put the pump in, im getting fuel out, and fuel back in via retuen line now, but no start up, and ive even jumped the FSS, with no avail....
Old Jun 20, 2007 | 11:34 PM
faststang94
did it run out of gas or something? did you crack the injectors and see if they are getting fuel?
Old Jun 20, 2007 | 11:35 PM
DNewton's Avatar
DNewton
my guess is the IP went out, or mabey just the FSS, its my understanding that if the IP is pumping fuel to the injectors, that they wont get it, and this happen when the FSS goes out...
Old Jun 21, 2007 | 08:55 PM
Dave Sponaugle's Avatar
Dave Sponaugle
If the fuel shut off solenoid dies, the fuel will go to the return lines, but not to the injection lines or injectors.
Old Jun 21, 2007 | 09:28 PM
DNewton's Avatar
DNewton
my point exactly, so it is possible for the FSS to go out? can i just replace it?
Old Jun 21, 2007 | 09:33 PM
DNewton's Avatar
DNewton
BTW Dave, i have fuel to the motor, and fuel coming back into the tank via return line, i can see it, i used clear fuel line, so it must be my IP, can i get another FSS solenoid?
joshofalltrades
25
Oct 11, 2013 10:36 PM
John Clugston
Jan 19, 2013 05:06 PM
rapidroy5858
May 18, 2012 02:27 PM
WishIhada7.3
Nov 21, 2010 09:43 AM
wbw189
Jul 2, 2009 10:39 PM
