First towing experience - 5000 lbs
Old Jun 21, 2007 | 04:05 PM
  #31
hogdogs's Avatar
hogdogs
The old farm truck we hauled feeder pigs in had an aluminum topper on it with an eye bolt at balance point. we had a self braking block and tackle just for it. it was on or off in 2 minutes including tightening the clamps....
Brent
Old Jun 21, 2007 | 04:46 PM
  #32
msb71's Avatar
msb71
NeXtra if you look at the yellow sticker on the valve cover it saids 5.8L just like mine does.
Old Jun 23, 2007 | 08:09 AM
  #33
NeXtras's Avatar
NeXtras
Originally Posted by Skandocious
The two intake pipes indicate that the engine would be speed density, not a 351. The single split pipe that my truck has indicates that it is MAF. The 351 can be either speed density or MAF, although from what I have seen the 351 only came in MAF in California. Thank you for insulting my intelligence by asking if I know which engine is under my hood
-Chris
Not insulting your intelligence =D Just learned something new though. I always thought the 2 pipes indicated 351 vs a 302.. Now I know... Now one more noob question.. whats the difference between Speed density and MAF
And yeh i saw the 5.8L marking on that yellow sticker a little while after I posted that reply
Old Jun 23, 2007 | 08:26 AM
  #34
Bruce R Leech's Avatar
Bruce R Leech
the difference is night and day. it is a whole different way of getting the measurement of the volume of air for the computer the MAF is a much better systome but you only get it on OBD II trucks
Old Jun 23, 2007 | 09:23 AM
  #35
Skandocious's Avatar
Skandocious
Wrong again, MAF is not dependant on OBDII. For example, my truck is OBDI!! OBDII didn't come until 96 and MAF was introduced several years before that if I'm not mistaken.
And to Nextras, I forget what the difference is between the two. If I remember correctly, the MAF uses actual air temperature readings to get the proper mixture in the combustion chamber while speed density relies more on a table? I don't quite recall. I also seem to remember that the MAF system mixes the fuel and air at a different point in the system than SD, but again I could be horribly wrong. Someone please correct me here.
-Chris
Old Jun 23, 2007 | 09:26 AM
  #36
Bruce R Leech
your right
I had a brain fart
Old Jun 23, 2007 | 12:15 PM
  #37
Mr. M's Avatar
Mr. M
No problems. I am thinking about doing a custom cold-air intake box because the FIPK, while increasing power, also substantially decreases fuel economy because of the hot air being pulled in.
-Chris
Hey Chris...
I forgot to mention. I've got those pictures of the intake box I built (with the cover removed, with the relocated resevoirs and drilled out radiator support for maximum cold air (or at least outside air). From your pictures...it looks like we started with the identical FIPK kit. With some patience, and some careful cardboard stencil work, you should be able to build it no problem.
I'll have to upload the interior pictures later this weekend. They are sitting in the boats locker.
Oh yea..about towing with the E4OD. I've got over 50k miles towing a 22' jet sled (4700lbs with trailer) back and forth from California to Washington. With the bed filled up and a full tank of gas (45 gallon aftermarket tank), I bet the weight was around 5500. This is with the stock 5.0 on the stock tranny cooler. The E4OD (properly maintained of course) does just fine...doesn't burn tranny fluid or overheat. Pulled just fine up the Siskiyou and Cascade mountain ranges. Shift kit helps as well.
When I clean out the boat, I'll post those pics of the inside with the box removed.
M
Old Jun 25, 2007 | 08:16 AM
  #38
bocephus_3349's Avatar
bocephus_3349
sry wrong post
Old Jun 25, 2007 | 01:06 PM
  #39
WinterRoad's Avatar
WinterRoad
-Chris
Just to add to the discussion a bit, and maybe further confuse everyone... my '96 has the 351 with MAF and OBDII, and it has two intake pipes from the airbox.
Old Jun 25, 2007 | 01:12 PM
  #40
NeXtras's Avatar
NeXtras
you sure thats MAF? canu take a pic of the engine for us?
Old Jun 25, 2007 | 03:55 PM
  #41
Skandocious
If it has 2 intake pipes then where is your MAF sensor? And what makes you think that its MAF?
-Chris
Old Jun 25, 2007 | 07:50 PM
  #42
NeXtras's Avatar
NeXtras
-Chris
my thought exactly lol... unless its 2 pipes that come into the MAF then out to the intake manifold... but y all that uneccesry stuff
Old Jun 26, 2007 | 10:30 AM
  #43
WinterRoad's Avatar
WinterRoad
-Chris
Hmmn. Now you have me wondering. My mechanic told me it was MAF. Think I will go and have a look later today and check a little better. I'll let you know what I find... or don't find. LOL
Old Jun 26, 2007 | 11:11 AM
  #44
whiteyfordzx5's Avatar
whiteyfordzx5
air intake systems from an engine's standpoint (written in first person)....
speed density: ok, the TPS is telling me the throttle is this much open, the MAP sensor says i have this much vacuum in the intake manifold, blah, blah, blah, blah, blah..... lemme look up all these values on a chart some Ford engineer wrote way back when (and is probably entirely too conservative)...... OK, here's how much fuel i should be adding to the mix based on how much air i THINK is entering the engine.
MAF: the MAF sensor says EXACTLY this much air is entering the engine. i should therefore add this much more fuel. tada. i'm done.
it gets a little more complicated in newer vehicles with computer-controlled timing (as opposed to a distributor), but you get the idea.
Mike
Skandocious
User Gallery & Picture Display
Jan 19, 2008 05:07 PM
Skandocious
68
Jan 19, 2008 01:06 PM
Skandocious
76
Jan 13, 2008 08:20 PM
Skandocious
37
Nov 7, 2007 12:17 AM
Skandocious
19
Sep 29, 2007 06:22 AM
