my alternator
Old Jun 25, 2007 | 10:30 PM
patjr_45's Avatar
patjr_45
my alternator
hey whats up i have a 94 f-150 xl and the alternator recently went out and i replaced it with the standard one. but at night when my lights are on my volt meter goes below normal and the lights dim out.any ideas???
Old Jun 26, 2007 | 12:43 AM
Bruce R Leech's Avatar
Bruce R Leech
did it have a bigger pulley? or do you have under drive pulleys? If there all stock then the alternator is week take it back
Old Jun 26, 2007 | 09:23 AM
SilverSport's Avatar
SilverSport
If that is a 2G alternator you also have to change the charging harness, or be sure you carry the larger fire extinguisher for Electrical and Chemical Fires.
Old Jun 26, 2007 | 10:59 AM
Bruce R Leech
it should be 3G so dont worry about the post above
Old Jun 26, 2007 | 11:21 AM
92F150Flare's Avatar
92F150Flare
If you are putting a stock one on.........make sure your battery is well charged.......you'll burn the alternator out fast if the battery is down below 12 volts.........they are made to maintain a charge.......not build one up.
Good Luck
