A tranny cooler is a pretty simple component, just like a radiator. I'm not sure if there are really any that are better than others, you just want to make sure you get a big *** one That's my understanding.
I have gotten 2 defiant brands from the parts stores and they are both made by the same co. the last ones I bought were Hayden. I only buy the big ones. they come in about 3 sizes. if you live in a cold Clement you can get a thermal bypass that will let your transmission warm up when it is cold out. but here we don't use them. I install about 3 a week and have not had any problems. but don't and I repeat don use the little plastic pines they give you to hold them to the radiator. the vibration will cause them to ware a hole in your radiator. I have repaired many trucks that have had this happen. get some strap steel and make some brackets to Mont them to the radiator support.
5000 lbs thats nothin for a 351. Ive had mine hooked up to 11,000 lbs before.
Also the truck looks great w/o topper. Not a fan of the truck caps. But looks great now.
I don't think I'd feel comfortable with that much weight behind my E4OD. I would have liked to have a little more control over my RPMs during my haul. You driving a manual or an auto?
Yeah, I've pulled close to that behind my '87 and she pulled it just fine, I wished I would have had some E rated 16's on the back end, but the ol 302 just chugged down the road, but unlike Scandacious I have a T18 instead of a E4OD, so I could completly control my RPM's.
No problems. I am thinking about doing a custom cold-air intake box because the FIPK, while increasing power, also substantially decreases fuel economy because of the hot air being pulled in.
-Chris
Yes ive got the auto E4OD in mine. Only 88k though. And the F150 didnt come available with 351 and Manual Trans. Only 351 & automatic
you sure thats a 5.8L... the more i look at it, thats a 302 intake... 351 had 2 seperate hoses while your has one big hose that splits at the end....
The two intake pipes indicate that the engine would be speed density, not a 351. The single split pipe that my truck has indicates that it is MAF. The 351 can be either speed density or MAF, although from what I have seen the 351 only came in MAF in California. Thank you for insulting my intelligence by asking if I know which engine is under my hood
