1978 - 1996 Big Bronco
Freakin Hubs!!!!!!!
Old Jun 19, 2007 | 02:35 PM
THE KING's Avatar
THE KING
Freakin Hubs!!!!!!!
Hey, I did a brake job on my truck last weekend. After figuring out what came off and stuff like that. I put it back together in the order and my hub bolts are tight but i can still move the hub casing around. I have the manual locking hubs and i locked them and put the truck in 4x4 and it went in. I wasnt going to worry about it but im starting to get grease on my wheels and i dont want to run the bearings dry. WUT THE HECK IS GOING ON!!
Old Jun 19, 2007 | 02:37 PM
THE KING's Avatar
THE KING
I also over tightened and stripped out the heads. so now i have a bigger problem. Whats the best way of getting those out?
Old Jun 19, 2007 | 09:32 PM
THE KING's Avatar
THE KING
Anyone? I need help!
Old Jun 19, 2007 | 10:23 PM
andym's Avatar
andym
You didn't put it back together right. Sounds like you forgot the snap ring just outboard of the hubs.
Old Jun 20, 2007 | 06:02 AM
Dazza's Avatar
Dazza
I found that you need to use an oversized hex or torx bit, hit it in with a hammer (softly!!) then undo with ease!
Daryl.
Old Jun 20, 2007 | 11:59 AM
helirich's Avatar
helirich
They also make reverse drill bits. You start to drill and if it grabs, it backs the screw off. I've used them sevral times.
Old Jun 20, 2007 | 12:05 PM
helirich's Avatar
helirich
I forgot to mention. About the grease leak. You might install new o-rings with some silicone. But the best thing is to put the crome dress tubes on. they go out just far enough to catch the grease that is flung. It wont fling it all. Mine have been leaking for years.
Old Jun 21, 2007 | 09:19 PM
THE KING's Avatar
THE KING
I put the big snap ring in. I made sure that i didnt forget anything. Maby the snap ring aint in the slot. Il have to take them apart this weekend and figure it out
Old Jun 21, 2007 | 10:35 PM
sb1234_99's Avatar
sb1234_99
I was just reading your info and realized your from capac. I'm from allenton and just bought a 78. I'm having problems figuring out exactly what I bought. If you could give me any pointers I would greatly appreciate it.
Old Jun 21, 2007 | 10:38 PM
THE KING's Avatar
THE KING
?? Whats the problem?
Old Jun 21, 2007 | 10:39 PM
THE KING's Avatar
THE KING
I know those trucks inside and out.
Old Jun 21, 2007 | 10:46 PM
THE KING's Avatar
THE KING
If you need any help doing anything on it give me a call il Private Message you my number
Old Jun 21, 2007 | 10:49 PM
sb1234_99's Avatar
sb1234_99
I'm not really sure how to do that
Old Jun 21, 2007 | 10:51 PM
sb1234_99's Avatar
sb1234_99
never mind I found your number I'll give you a call this weekend. May be you can help me figure this thing out
Old Jun 22, 2007 | 11:06 PM
THE KING's Avatar
THE KING
Ok i work from 9 to 3 on saturday and after that im gonna be putting my 360 in my 250 highboy and getting that running.
